High praise, indeed!
Thanks will try tomorrow.
How do you fix the crossed rear channel in the software,
How is this amp powered?I think this is the version B DSP, in which case it is an amplifier and is software tuneable. US $72.0 17% OFF|Car Intelligent Audio Sound Processor System 4X50W Car Audio Processing Amplifier 15 Band EQ DSP Equalizer Precision Tuning|Multichannel Amplifiers| - AliExpress
The purple wire on the sub input. They said to cut the wires and reverse them.
Latest 1121.xps file correct reversed balances right/left and rear/frontthis is the lates file that hansshow sent for lowering the high notes and chimes, unzip and rename to remove the other .zip, it should be a .xps file, it helps a lot, channels are still crossed in this file, so you have to use the software to correct that,. i find that a smilie face in the car tone settings also helps, not close to my car but pretty sure i have from left to right 3 1.5 0 1 1.5 or something in that range
It is not version B, the shell looks are the same, but the circuit board, IC is different.I think this is the version B DSP, in which case it is an amplifier and is software tuneable. US $72.0 17% OFF|Car Intelligent Audio Sound Processor System 4X50W Car Audio Processing Amplifier 15 Band EQ DSP Equalizer Precision Tuning|Multichannel Amplifiers| - AliExpress
I got the versiin E installed today. So issues
1 Rear channels reversed.
2 Music sounds hollow vocals are high and bass ia somehow not as good
3 Chimes are loud.
If anyone figures the right music setting in DSP please share the XPS file.
Did you test the codes? I tried on the basic DIY kit and none of those worked.
I'm curious why there isn't version b software being published similar to the version e updates I see so often?
I appreciate hearing that. I hope they are treated equally and get configured to their best. I look forward to hearing more about any updates to version b DSP. You wouldn't happen to have a github repo I can subscribe to for when the updates start? Thanks.
Sir, you may make a huge mistake, please google what is LPF means, low pass filter.But the subwoofer is only 40Hz - 150Hz (based on HS documents)? You shouldn't hear anything under 40Hz!
