If your wife's peripheral view is so limited that she can not see the speedo on the main screen, is it then a good idea that she is driving on the road where you risk hitting someone if your "viewing angle" is that limited ?Got the display installed yesterday, pretty painless process thanks to a youtube video. Works fine. Honestly I don't really want it there (it blocks the "blast my face" AC vent) but my wife insisted on it as a condition of buying the car due to her peripheral vision issue.
I would, since it plugs into the wiring harness, but that’s just me. I wouldn’t want to give them any reason to void my warranty.Got this message a couple times today. However the drive home no message. Not sure what's going on. This is on 2023 Model Y with about 3,000 miles.
Probably will make a service appointment to have them check it out... Should I remove this mini dash screen before bringing it in??
What message did you see? I am confused.Got this message a couple times today. However the drive home no message. Not sure what's going on. This is on 2023 Model Y with about 3,000 miles.
Do you use a sunshade, or leave it directly in the sun? Just curious, as I have had mine for a while now and never leave it exposed. My car is garage kept and when parked outside, I always use a shade. Have not had this issue… so far.After installing it, a few days later this happened. I believe it due to the heat of the interior (100+ deg). It started out small but begins to spread out. Hanshow was able to replace it, but the 2nd unit had the same issue. I guess just make sure to keep it cool during summer time.
My house only have a driveway so it’s outside 100% of the time. I just recently bought a sunshade for the windshield and the glass roof. I’m sure it probably helps, but unfortunately once it happens, if the interior reaches over 100 deg, the product will suffers from this defect.Do you use a sunshade, or leave it directly in the sun? Just curious, as I have had mine for a while now and never leave it exposed. My car is garage kept and when parked outside, I always use a shade. Have not had this issue… so far.
Where I live it will hit 130 degrees outside, and it’s regularly that in the car these days, even with the sunshade. I also have a roof shade. So, unless I’m driving, the sun doesn’t hit my display. I can only imagine that getting hit with that much direct sunlight and heat, can’t be good for the display.My house only have a driveway so it’s outside 100% of the time. I just recently bought a sunshade for the windshield and the glass roof. I’m sure it probably helps, but unfortunately once it happens, if the interior reaches over 100 deg, the product will suffers from this defect.
Yeah! Your display would definitely melt in that heat. I now have my cabin protection on at 100 deg. The replacement display also suffer the same fate after forgetting to use the sunshade for a few hrs at 75-80 outside temp.Where I live it will hit 130 degrees outside, and it’s regularly that in the car these days, even with the sunshade. I also have a roof shade. So, unless I’m driving, the sun doesn’t hit my display. I can only imagine that getting hit with that much direct sunlight and heat, can’t be good for the display.
I have the same issue. Installed it and then my car was at the body shop to get the rear hatch replaced. Got it back today and I have the same spot on the top right and bottom left. I guess I’ll have to reach out for replacement.After installing it, a few days later this happened. I believe it due to the heat of the interior (100+ deg). It started out small but begins to spread out. Hanshow was able to replace it, but the 2nd unit had the same issue. I guess just make sure to keep it cool during summer time.
Was your car left outside in the sun? If it’s still within your 30 days I think they will replace it for you.I have the same issue. Installed it and then my car was at the body shop to get the rear hatch replaced. Got it back today and I have the same spot on the top right and bottom left. I guess I’ll have to reach out for replacement.
Yes it was left outside. It’s over 30 days now. Took 2 months to repair a small scratch and dent on rear hatch.Was your car left outside in the sun? If it’s still within your 30 days I think they will replace it for you.
Did you get it?I already bought the 5.16" to replace my 4", now I'm probably gonna get that latest screen in the video above
