AnxietyRanger
You mean like the 100D having 102 kWh? Or 70D that was higher than 70kwh? Or having 0-60 scores better than advertised? Well that's inconvenient for your argument. A few off the 85 is small timer
Yes, Tesla cleaned up its act on the 100 kWh. They also cleaned up their act (probably) on P90DL performance after a court was about to order them to pay damages... We all hope these are signs of Tesla changing for the better after being called out on it enough times.
As for your 70 kWh example, that actually helps prove the point. Not dismiss it. The point is: Tesla was realistically portraying their low-end or small battery capacity (or even under-reporting it in instances), while until 100 kWh they were inflating their high-end or large battery capacity (85 kWh and 90 kWh). People speculated this was done to inflate the difference between the more expensive large battery vs. the less expensive small one. The explanation makes sense, this policy was very consistently making the higher-margin product look better than it in reality was. Why were just the large battery figures inflated? Never the small battery ones (those were even at times deflated)...
Same was happening with the way Tesla was reporting their large battery non-Performance vs. Performance range (in miles/km), the former was in certain clear and repeated instances reported artificially lower than the rest, even though math and experience would have given non-Performance better figures. Arguably, the speculation goes, this was to keep the more expensive Performance looking better. For some reason only the large battery non-Performance version (the one competing with the more expensive, higher-margin Performance version) had deflated range figures whereas all others followed a clear and same mathematical pattern...
@Magus, people are not stupid. They can see when they are being played and unfortunately since a more benign start, since late 2014 Tesla has been arguably playing people in several instances (which exact instances, of course, matter of speculation).
