PianoAl
Same. Way too hot. Need more fat in my butt??Speaking of the auto feature...I find it 100% useless. Anyone else?
It's not automatic because you did not pay for FSD.Yeah, I do that all the time. I want fully automatic and am puzzled as to why it's not.
It's not that they are hard to get right for everyone, something like this is fundamentally IMPOSSIBLE to get right for everyone. Clearly it works well for some, but not for all. Like you say, some different profiles might help. But for many of us, we would just like a way to turn off the auto feature and have it stay off forever.It's funny, I find auto seat heaters too warm. I like the initial warmup but I would want them to shut off as soon as the seat has reached my target temp^, no more otherwise I feel sick. Other people here complain that they don't warm enough. It just shows that automatic things are hard to get right for everyone. We'd need a configuration for what automatic should do on our personal profile
I do have FSD, but I haven't turned on the beta. Yet.It's not automatic because you did not pay for FSD.
Like me. Auto never leaves them on long enough for me.It's not that they are hard to get right for everyone, something like this is fundamentally IMPOSSIBLE to get right for everyone. Clearly it works well for some, but not for all. Like you say, some different profiles might help. But for many of us, we would just like a way to turn off the auto feature and have it stay off forever.
If you have FSD, max speed should change automatically. FSDb is not required.I do have FSD, but I haven't turned on the beta. Yet.
Doesn't for me and many others. I'll make a video, and maybe we can figure out what's different in your car.If you have FSD, max speed should change automatically. FSDb is not required.
Since the car frequently (not always) misinterprets "55 MPH for trucks" and "55 MPH while towing" signs as if they applied (no towing by a Model 3, right?) it's a darn good thing it doesn't automatically reduce the TACC speed.Yeah, I do that all the time. I want fully automatic and am puzzled as to why it's not.
Disagree. I have had EAP since day 1, paid for FSD three years ago, and have had the FSD computer for two years. Unfortunately, my car has never automatically adjusted the AP set speed based on speed limit signs, which it does read and display correctly on my screen. The only time I have had it slow down based on perceived speed limits is on stretches of highway where it suddenly and erroneously thinks it is on an off-ramp or surface street, likely due to mapping errors combined with insufficient GPS precision. That kind of slowdown is highly undesirable.It's not automatic because you did not pay for FSD.
Tesla knows our butts more than us They decide how much heat those buns needSame. Way too hot. Need more fat in my butt??
Another agree on this. I have full paid FSD, but not yet FSD beta. On my 2021 MYLR. I have repeatable behavior of turning onto roads where the speed limit signs say 45, but the map, or whatever default limit is in place, has it at 35 or whatever. If I re-engage AP In that state, I can't spin it up beyond that incorrect limit plus offset.Doesn't for me and many others. I'll make a video, and maybe we can figure out what's different in your car.
Here's video.If you have FSD, max speed should change automatically. FSDb is not required.
Do you have NOA enabled? I don't know if it matters, but I never disable NOA. When NOA is active, the car adjusts max speed based on reading signs. Unless the sign is blocked by another vehicle, it is rare for my car not to read the sign and adjust my max speed accordingly. This was the case before I had FSDb, so that should not be a factor. As I say, the only time that I do not use NOA is when bad weather causes NOA to drop into AP.Another agree on this. I have full paid FSD, but not yet FSD beta. On my 2021 MYLR. I have repeatable behavior of turning onto roads where the speed limit signs say 45, but the map, or whatever default limit is in place, has it at 35 or whatever. If I re-engage AP In that state, I can't spin it up beyond that incorrect limit plus offset.
When I get to the speed limit sign, AP will recognize the "new" limit but will not raise the set speed by itself. However that is the poin at which I can manually spin it up to the marked speed plus offset. (I was unaware of the single-click stalk method, so I'll try that soon.)
It only response automatically to a changed speed limit that is lower than the current set speed, not if it's higher. It will lower the speed if it sees a sign as mentioned above, or if the map data tells it that it has entered a section with a lower speed limit. (Again, said map data may not be correct.)
I'd also like a setting for the opposite of this in the summer -- default to having the passenger vent on for AC. On triple digit days, it simply doesn't cool the car if the passenger vent is turned off so I have to manually turn it on when driving by myself (which is at least 90% of the time).1 easy fix....able to turn off passenger vent when someone sitting there
This behavior is not in NoA territory i.e. freeway. FSD-AP on suburban multi-lane roads with traffic-light intersections.Do you have NOA enabled? I don't know if it matters, but I never disable NOA. When NOA is active, the car adjusts max speed based on reading signs. Unless the sign is blocked by another vehicle, it is rare for my car not to read the sign and adjust my max speed accordingly. This was the case before I had FSDb, so that should not be a factor. As I say, the only time that I do not use NOA is when bad weather causes NOA to drop into AP.
at least it's able to do manuallyI'd also like a setting for the opposite of this in the summer -- default to having the passenger vent on for AC. On triple digit days, it simply doesn't cool the car if the passenger vent is turned off so I have to manually turn it on when driving by myself (which is at least 90% of the time).
