Glan gluaisne
The Tesla unit uses a more expensive type of RCD than most/all other charger designs in the UK, and doesn't qualify for the OLEV grant so you miss out on that saving too.
Nothing different at all about the Tesla charge point as far as RCD provision is concerned, with the exception of those charge points that use some form of magic in order to (allegedly) get around the provisions in Section 722 of the regs. All charge points have to comply with Section 722, and that normally means either installing an expensive Type B RCD, or using a fairly cheap (typically ~£18) Type A RCBO with an earth electrode. The latter method is the one almost universally used, and will work just fine with a Tesla charge point.
