How are the model X and model S pucks different?
Our local Costco has a set of low risers that will fit the Tesla pucks... you may want to inquire next time
Here's one I made with carbon fiber impregnated poly-carbonate. It's very stringy because of the cf strands but it's very very strong. It has 11.4 times the compressive strength of ABS.
Has anyone seen a 3D printed jackpad ? One constructed out of plastic would have limited use, but if I could get a dozen uses out of it, that is fine. It makes sense to put one of these in the trunk in case of a flat tire on a road trip. If plastic isn't strong enough, design could include attachment to a small metal plate for weight distribution. Others have used successfully used a 2 by 4.
I would not trust that for a secondHas anyone seen a 3D printed jackpad ? One constructed out of plastic would have limited use, but if I could get a dozen uses out of it, that is fine. It makes sense to put one of these in the trunk in case of a flat tire on a road trip. If plastic isn't strong enough, design could include attachment to a small metal plate for weight distribution. Others have used successfully used a 2 by 4.
Has anyone used this (4 Pack) Rubber Screw On Bumpers - Shed Doors, Sliding Door & Cabinets https://www.amazon.com/dp/B07GBFD3SH/ref=cm_sw_r_cp_apa_i_eZ-tCbMYQ2JE6
To be used as the pin in the center hole. According to the measurement it would be slightly too big but if there is some give in the material it should fit.
Bought them and attached to 4 hockey pucks using 1 1/4" drywall screws. Have not tried to lift the cars with them yet, but with dry fit they are snug, but seem like it will work. Will post back when I lift my 3 later this week. Will probably change wheels on the S this week also.
Turns out they were slightly narrow for my S. wrapped electric tape around them and they give a snug fit. Here's a thread I made for it: DIY jack pad
Thanks! I'm thinking about buying one to keep in the car so just in case I have a flat tire out of nowhere and Tesla service is not available. This way I can make sure the car is not damaged by someone else.
How many did you buy? Is there any reason to buy more than one of these? Would it make sense to buy 4 so if you ever take your Tesla to a tire place they can lift the car from all 4 lift points?
Tesla Model S Jack Pad Adapter Lift Pad Tire Service Murphy's Law Jack Pads | eBay
