From the other real Tesla forum: "NOTE:When the low-power consumption mode is active, the auxiliary 12V battery is no longer powered and may go flat within 12 hours. In the unlikely event this occurs, you may need to “jump start” or replace the 12V battery before you can charge."
So that may indeed be your problem. 12V battery is here: http://www.teslamotorsclub.com/showthread.php/10349-12-V-battery-pictures
Its working. had to take half a car apart though
Reports are that you simply need to apply 12VDC to the posts behind the nose cone, and the car's systems should -- within a minute -- begin charging the car, and recharging the 12V system. Use jumper cables and an existing car battery and you should be fine after a few moments of applying the voltage.
Just want to commend you on getting a Model S to Latvia! Glad you got it working.
When I'll have the plates and the snow melts+1 Well done! Let's see some Model S pics from the Latvian countryside.
Yes! Someone has done this mod (amber rear turn signal)??? Could you please either tell me here how this was done or PM me?They had to add orange turn-indicator light into the back fender (not visible in the pictures below) and other modifications to get it approved.
Thanks!!!
Here is a pic of the mod. You can see the additional lights.Yes! Someone has done this mod (amber rear turn signal)??? Could you please either tell me here how this was done or PM me?
Thanks!!!
If Tesla is not able to contact the car (since you're on the wrong continent with regard to cell phone coverage) perhaps pulling out some fuses and waiting 20 mins then popping them back in could help? Also, if your car was delivered with the 4.1 firmware maybe you have the 12V battery issue? Try to attach an external 12V charger to the charging connectors (behind the nose cone) and see if that helps after some hours of charging? Please update how it goes!
They didn't mod the rear lights. They have added new rear amber turn lights to a new Hole Ine the rear bumper.
Owner is ferdinand-motor.no.
On the other side, I have been thinking of this connectivity issue for the car - as it is AT/T based.
In Norway i could buy a 3G enabled router to Connect to the car (power) and get a hotspot. Can you do that In Latvia?
Also, as for what I remember, AT/T provides a signal booster for people without phone coverage, that connects to your router and basically gives you your own 3G/phone service.
Could you Connect a router to power on your Tesla, then set it up to use a VPN service to get a US IP adress, so that the connected AT/T 3G/phone enabling device would create a phone betwork for your car to Connect to and use the normal services availible?
Like this:
Internet <-> router w/VPN <-> AT/T signal device <-> car
Tapatalkin' from iTalatut...
Thanks for the advice. Thats what I defiantly gonna try next.
But you know what the funny thing is? My maps, navigation, browser, and internet radio aren't working because there is no internet. BUT I do have a reception of all 5 sticks and my firmware just updated. Which I find very weird cause I don't think that Tesla is paying for the roaming to Latvia It might have downloaded while the car was still in US and just installed here....
