7.8% reduction is average for 15k miles for M3, so you are close.
You sure about that? I’m holding steady at 298 miles on the display (was 310 initially ...). That’s only a 3.8% drop.
Almost 24k on the odometer.
8% is not normal, 4-5% I can see but 8% is not, 4 years -32%?
Yep, good idea. Ideal long term storage SOC is usually around 40%, so with limited driving I've been charging to 50% and recharging when it gets down to 30-35% (100 miles remaining) or so.I'm at 8% lol but who know what that is about. I am charging to 50% since i'm not working onsite, therefore no need to sit at 70% charge all the time. As long as 50% doesn't harm the battery and it only affects the BMS calibration than I'm ok with this.
Right I’ll go back to charging at 90 upon departure when the time comes.Yep, good idea. Ideal long term storage SOC is usually around 40%, so with limited driving I've been charging to 50% and recharging when it gets down to 30-35% (100 miles remaining) or so.
I have definitely noticed a drop in reported "100%" indicated range since doing this. Previous normal charging was charging to 70 or 80% and recharge when down to 100 miles or so.
Since you were having good luck with 60% and I was having bad luck with 50%. I'm not worried about it knowing that it's just "paper" losses, but apparent rated range has gone down a lot since I changed my charging habits from charging up to 70 or 80% and recharging at 30% or so, to only charging up to 50%. So last night I charged up to 60% for the first time in a while and when I checked the car later, it had undercharged by quite a bit. So at least it seems like going up to 60% seems to help the BMS calibrate better than 50%, which I found surprising. We'll do this for a while and see what happens. I'm sure the the long-term differences between 50/60% SOC are minimal at most.I thought I'd try 60%, since there was that "scientific" thread that explained cathode cracking occurred above 3.92V, and that's supposedly 63% SOC. Since I don't need the range, except for trips, I didn't see any harm in trying 60% SOC out. Of course, my result is just a single datapoint.
charge it to 100% every day
Even charging to 95% should dramatically improve long term battery life compared to 100%. Might be better off mapping out a Supercharger to top off for a couple minutes near home on the way back on those odd days when you use more energy than normal.You should start a separate thread in batteries and charging to hear the discussion of why you don't want to do that. Especially since it seems you only NEED to charge to 80% to get to work and back, with a cushion.
I switched from 80% SOC to 60% SOC at 7500 miles, over a year ago. I haven't noticed any BMS drifting or cell imbalance issues; only wonky rated range estimates due to seasonal temperature changes, with a few blue snowflake days thrown in for good measure. 60% seems okay, but 80% was okay before that as well.
Very awesome post.... I'm sitting around the same rated range of 270s now also with 55k miles. I have to charge it to 100% every day and then it sits at work with 63% +/- 3% with sentry off so I can get home with ample charge remaining. Wondering how I can manage to get mine to rebalance... Probably will never happen.
EDIT: Just thought about TIME. For us, to get from 90% to 30% without traveling it'd take about 2 weeks. A regular battery can get sulfated if kept discharged for days. Just want to make sure the Tesla battery doesn't mind that. So my question is if you can do 90% to 30% regardless of time, or something like 90% to 30%, or once a week, whichever occurs first? Thank you.
