Anyone have insight into this?Makes me wonder what's happening when people report a stall charging at 50kw-60kw (which has happened to me several times recently). Maybe a broken single charging unit in the stack.
Situation: Tifton GA today is full, (7of8, 1 being broken), and upon plugging in (22%SOC) I immediately got 48kw. Within two minutes I was at 51kw where it has held steady for the duration of the SC event (ended at 80%SOC)....
No, what it suggests (and is consistent with other reports) is that supercharging is slower at very low states of charge, until you get up to 10%.Today I had a warmed X P100D battery at 1% SOC, supercharging at the oldest supercharger in Japan. It went to 30kW with AC off. I was paired and I was second. Then after 10% the power went up to 90kW.
This seems to suggest that:
- in this specific case, the first car was over 80% and drawing minimum power when my car reached 10% SOC
- Old superchargers seem to have 10kW x 12 stack, rather than 12kW x 12 stack.
Can we ask Tesla to upgrade to new chargers?
Yes, that is a behavior that has been observed for quite a while in the newer types of batteries. The battery chemistry Tesla used to use in the really old 60kWh and 85kWh battery packs, like up until about 2014-2015 was a bit different. It was like the lower the better, and the fastest charge rate was from low single digit %. Since the 90 and 100 packs, they do have that different behavior, where they stay cautiously slow up to 10%-ish before ramping up fast.No, what it suggests (and is consistent with other reports) is that supercharging is slower at very low states of charge, until you get up to 10%.
Yeah I know - my bad. I meant they happened at the same time; under 10% and the other car being up 80%. If the other car was pulling more power, my power after 10% wouldn't be 90kW.No, what it suggests (and is consistent with other reports) is that supercharging is slower at very low states of charge, until you get up to 10%.
A pair of stalls under perfect conditions should deliver ~145kW between the two. The problem is as we all know, it's never perfect conditions outside of commissioning day maybe.When a site is full (or close to full) the power is often reduced. I have seen this many times. When I add up the power between my car and the other car on the other paired stall it doesn't add up to 120 kW. Often not even close. I believe the total power a site is able to deliver is lower than the theoretical maximum. For example a site with 8 stalls would be able to deliver 120 kW x 4 = 480 kW. In reality it often cannot. So when a site is getting full some cars will get less than they could take. But of course there is always the odd situation where a car decides it can only charge at a limited rate for no apparent reason. I have seen this several times when I was the only one at a site and still got less than the normal speed.
Superchargers have max output of 135 kW, not 144 kW, with a max of 120 kW allowed to one car.
There are losses of a few kW between a supercharger's output and the input a car receives.
It's very close to that. It's not just leftovers to the secondary car. They do have it set so the secondary car will get at least 30kW minimum. So in certain circumstances that can reduce the primary car's speed just a little.For older style V2 superchargers this is dynamic with a max of 120kW to one car, and leftover power to the second car.
Yes, all of the 90kW ones have been upgraded.(V1 superchargers were limited to 90kW, but they have all been replaced at this point I think at least in North America.)
All of the new ones being put in are the 145kW type. But there are still many of the older ones that are still 120kW and 135kW.So maybe some locations might be limited to 135, but I've personally seen 145kW.
If I've followed OP correctly, the paired car was drawing in the neighborhood of 84kw since I was not receiving more than 60kw (but was receiving more than 48kw). I think this all implies that for some reason my car wasn't able to receive 60kw. Seems like it's either that, or perhaps the overall SC location was overdrawn, or the chargers were overworked today and too hot to provide full 144kw between the two paired vehicles? It's odd (to me) since based on OP I'd have expected to receive a multiple of 12kw...48 or 60 presumably since I was obtaining 51kw. And it is 50 degrees and cloudy today, so my pack shouldn't be anywhere near as hot as it has been in the summertime when I've used this same SC location (yet it was empty in the summertime weekday visits), so I don't see my pack being a limitation here.
Help?
I think your analysis is flawed. If the charging is done by 12 kW units as the OP stated, then the paired car may be charging at 73 kW which than must use 7 of the available 12 chargers, wasting 11 kW.
I do rather doubt they limit the total site power. I can't see a reason to do that.
I don't know how expensive those switches are compared to just adding more chargers. Tesla came up with a reasonable compromise between cost and available charge rate. Pairing made sense in the early days when the battery packs would taper down quickly. My old 85 only accepts 58 kW at 50% SoC. Today is different. A Model 3 or S/X 100 charges at around 100 kW up to 70%. There just isn't much power left the entire time a Model 3 or S/X 100 charges on the other side of the pair. Ideally a supercharger site would have all stalls connected to one big charger that can divert to all stalls individually. Every car would get the maximum rate all the way up to the limit of the site. It would not matter where you pull in. I guess that would be a wiring nightmare, though.
As for upgrading existing sites. From what I have learned, the wires from the cabinets to the actual stalls are pretty much at their limit. They are not able to sustain much more power, especially not over a longer period of time. Those are down in the concrete so they would be very difficult to upgrade. The only way to get significantly more power is higher voltage. That would require a new pack. Maybe with the Model Y and Model S refresh it will come. I believe the Tesla plug is also at the limit of what it can handle in terms of Ampere. So again, only higher voltage would enable a higher rate.
On the contrary, other owners will love you for occupying those less favorable stalls. Please keep up the good work.This is great information. I had no idea and have probably frustrated a driver or two when I’ve pulled into a stall next to a car when there were other chargers open.
