I do understand that and I have tried to make the point before that the billing is not a significant issue for Tesla either.
I am pretty sure it is. The levels of power Tesla uses are extremely high--higher than even most of the commercial retail types of locations where they are hosted.
Unlike many facilities that have high startup surges on motors the Superchargers have entirely contained maximum power draws.
...that are still REALLY high. It's not like it's some arcing surge. It's just really high power levels for tens of minutes at a time. That will still put them into some expensive demand charges.
It would be good if you read the entire thread rather than replying to a single message.
I have already read all of this thread, but to see you still saying such incorrect things about it shows that you still don't understand it.
Exactly. Utilities monitor the LARGE customers. Tesla is not a large customer as I have explained clearly.
...clearly wrong. Tesla is a
HUGE electricity customer. The sites need to arrange for their own very large transformer from the utility. They are capable of power levels in the 1 to 2 or more megawatts, and certainly more for the 40 site locations. Any megawatt scale customer is absolutely a large customer that is monitored and assessed by demand charges. This fact that you think Tesla Supercharger sites are not a large customer of the utilities show that you have no clue about this.
Tesla Superchargers don't really have a "peak" draw in the same way other users do. They draw a maximum of 144 kW per Supercharger pair, period. No need to go on about how to mitigate this.
I saw you kind of mention this earlier, and I thought, "Surely he doesn't misunderstand it that badly. He thinks each stall is a customer?" More likely you seem to think that the word "peak" only applies to some outlandish momentary insanely high spike for less than a second. That's not what this is about. Peak power for demand charge can still bite hard for these longer periods of 144kW because sites have 10 or 20 or 40 stalls, and their accumulated power can be really high when a lot of cars are there and much lower when few cars are there. See where the "peaks" and "valleys" are in this scenario?
That's what they are designed to do and that is how they will be billed. Locations like Gaithersburg, which often has nearly all if not all stations occupied, will draw the maximum during peak times. That's the reality.
How they will be billed is by what their peak power level is during the year. If Tesla can buffer that by battery storage to serve those peak loads themselves instead of drawing those peak loads, then they reduce their top power level that applies all year long, and that saves them significant money. Since they are
already doing this, it is obviously already useful and important to them. So let me illustrate:
You want to refer to Gaithersburg, MD? OK, let's use that example--that's 12 stalls. If those are all full, and some mix of charging speeds from the cars, but pretty much assuming all the power is split however it can go, that's 144 kW times 6. That's 864 kW peak when all of the equipment is running full-out. If they put in some large battery storage, they could cover those full times from battery and refill it at other off-peak times, and even keep a steady draw from the utility that is less than that 864 kW. So by letting it ebb and flow and feeding the top load from the battery, they may be able to reduce it so they never draw higher than 300 kW or 400 kW from the utility at any point. That reduces their maximum peak load and keeps that site cheaper to run.
You are the only person talking about blacking "out neighborhoods".
You were the one talking about whether it would be hard on the power grid, like so:
That station could turn on 100% and back off again every hour and the power company would not even notice. EV charging is so inconsequential to the power grid that it means pretty much nothing.
They will "notice" in their accounting department so far as logging the peak power to apply that tier to Tesla's bill.
Don't be ridiculous and don't put words in my mouth.
So yeah, those were my words to your idea. Granted, I used some hyperbole to snark on your idea a bit--sorry.
