How to Jack up an S not using jackpoint Stands
Discussion in 'Model S: Interior & Exterior' started by Brightonuk, Jan 25, 2015.
  1. Brightonuk
    Brightonuk Member
    Plantation
    I am looking to paint the calipers which look straight forward enough but how to jack the car and not use jackpoint jack stands (did not want to spend $600+ for stands I will use once)
    The only other option I see is using four floor jacks (With hockey Pucks on the four jack points) but that is not the safest way to suspend the car for an extended time and I need to let the caliper paint cure for 24 hours before I can apply the decals, then I need another couple of hours to apply the clear coat and let that dry.
    Can I use jack stands under the front and rear axels?
    Any other suggestions?
  2. rtz
    rtz Member
    United States
  3. jordanthompson
    jordanthompson 2010 2.0 Sport, VIN 0683
    Satellite Beach, FL
  4. Brightonuk
    Brightonuk Member
    Plantation
    But you cant remove the wheels with that system
    The lift points are fine with a low clearance jack but the issue is how to support the car one it is up on the jack, you cant fit a jack stand under the car while it is up on a floor jack.
    A member close to me has two jackpoint Stands so I may have to do the front then the back which should be OK as long as I don't waste any time (The paint has a working time of about 4 hours as I am in FL it is a little warmer than you guys right now):cool:
    Another option is Powder Coating $75 each caliper x 6 + $50 per hat + $160 for removing the calipers reinstalling them and bleeding the brakes I don't know if that extra cost is worth it as painting with the G2 system has great reviews and is a fraction of power coating cost.
  5. roblab
    roblab Active Member
    Angwin (Napa Valley) CA
    Sure. Using one jack:
    Jack up each tire as you need
    Remove wheel
    Paint caliper
    Reinstall wheel- don't need to torque wheel yet
    Do next tire
    Etc.
    The wheels don't touch the calipers. Let them dry.
    Repeat to install decals.
    Torque down lug nuts before driving
  6. AMPUP
    AMPUP Member
    Dunn Loring, VA
    That is my plan in the spring.... I would suggest you power-wash the calipers with the wheels on and let dry prior to starting the work, that way you can immediately mask and paint when removing each wheel.
  7. Brightonuk
    Brightonuk Member
    Plantation
    #7 Brightonuk, Jan 26, 2015
    Yep I think I will follow robs advice and save the $800++
    This is the photo the powder Coating place sent me to convince me that Powder Coating is the way to go
    They do look pretty awesome
  8. AudubonB
    AudubonB Mild-mannered Moderator Lord Vetinari*
    My input is that Roblab's idea is the best; esp. because to answer another question of yours: NO, I do not believe you can use jack stands under the axles - you simply do not have access to them.
    (On edit: - computer hadn't been updating - seems my reply was a bit delayed!)
  9. AMPUP
    AMPUP Member
    Dunn Loring, VA
    So how will the plan work with powder coating? don't you have to remove the actual caliper? I assume this would mean more than one day of jacking up etc? just curious how powder coating would work vs using the G2 system?
  10. randompersonx
    randompersonx Member
    Orlando, FL
    I was always told not to do long work while on jacks as they can lose pressure and fall (either slowly, or suddenly). Only use a jack for quick jobs (like changing a tire), or putting on a jack stand.
    The rule is of course much more important if you are doing work where you will get under the car, but it's still obviously a pain in the ass if the car drops without a tire, even if someone isn't under it.
    On the other hand, if there is no center jack point, and no access to the axle, I'm not really sure how you would get the car on jackstands anyway.
  11. tga
    tga Supporting Member
    New Hampshire
    #11 tga, Jan 26, 2015
    On the first gen Mini's (02-06), you can put a 2x4 between the jack points, lift the entire side, place stands under the 2 jack points, and lower the car unto the stands. Repeat for the other side. There's enough strength in the side to support the weight of the car, distributed over a wide area:
    What does "safe stabilization for a side-resting Model S" mean? Maybe the Mini trick works? Check with your service center before trying!
    After moving the jacks under the tire and raising it further, you could lower it onto a jackstand, rather than locking the wheel support in an extended position.
    All in all, Roblab's suggestion may be the easiest, unless you know someone with a lift.
  12. Brightonuk
    Brightonuk Member
    Plantation
    Now I am thinking that powder coating looks reeeeally good
    Dam............. The wife would kill me but it does look reeeeeally good
    And in gloss white (Just to be different) with black lettering and logos (Which are coming) would look really good.
    Crap.....OK I will rationalize this .. Center console in CF $800............. way to expensive........... redo all the calipers and hats $850.........worth it (in my mind)...........Three weeks of grief from the wife for spending $850 on painting calipers.........??
  13. Bill D
    Bill D Member
    Weston, FL
    When jacking around under your Tesla, be sure you mind its bollocks.:smile:
  14. artsci
    artsci Sponsor
    Timonium, Maryland
    #14 artsci, Jan 26, 2015
    To powder coat calipers they have to be completely removed and you know what a relative PIA that is. I've done it before and frankly my impression that the epoxy solution is almost as durable and a lot easier.
    - - - Updated - - -
    I don't think the jack stands in the photo are robost enough for the Tesla, which probably is at least double the weight of a Mini. For safety's sake always check the jack stand weight rating.
  15. linkster
    linkster Active Member
    USAX2
    ....and completely dis-assembled since the heat during the powder baking/adhering (post coating) process will melt the elastomeric seals.
  16. EarlyAdopter
    EarlyAdopter Active Member
    Redmond, WA
    It means it's a safe place for first responders to use to brace a car that's rolled on its side. It is not a safe place to support the full weight of the car.
  17. Brightonuk
    Brightonuk Member
    Plantation
    #17 Brightonuk, Jan 26, 2015
    OK guys as much as I like the look of the Powder painting is the way to go
    One last question as far a clear coat goes G2 advises against using any due to the fact it can yellow and as I am going with white caliper's this is a real concern.
    Any thoughts on using a sealant such as HydrO2 / CQuarts / EXOv2 or another protectant in place of clear coating the calipers.
  18. artsci
    artsci Sponsor
    Timonium, Maryland
    And bleed the brake lines when they're reattached, etc., etc.
  19. Brightonuk
    Brightonuk Member
    Plantation
    Na Im going with the G2 Paint as you said etc etc = 3-4 days down time $600 to powder Coat $360 to remove reinstall the caliper's bleed the brakes and store the car for two days and add another @ $100 a day storage.
    It was a nice thought but just too much aggravation an expense, once I complete this project I will post photos as I do not believe anyone has gone for white caliper's
    I think CQuartz to seal the decals I had excellent results using it on the body and it seems to have a better than average high temp limit (Guess I will find out next time I track the car) :scared:
  20. scottm
    scottm Version 9 software sufferer
    Canada
    Here's how you jack a car with air suspension option:
    Park with car in very high mode.
    Place blocks under all four jack points, blocks just high enough to squeeze in there.
    Put car in normal height and all 4 wheels lift.
    Take off all four wheels.
    ..just an idea.
