eprosenx
If your jurisdiction is on 2017 NEC, you should be able to use 6-6-6 copper or 4-4-6 AL type SE (including SER or SEU, I believe, but not type USE) cable.
Under 2017 code you are not required to derate this cable type to 60C so long as the conductors are 8 AWG or larger. This will get you significantly more ampacity than Romex (NM-B) without going to conduit. Certainly enough to charge at 48A.
The Lowe's site has 6-6-6 Cu for $2.24 a foot. But the 4-4-6 AL is a particularly good deal - $0.67/foot at wireandcableyourway.com.
Good callout on the SE cable! I have thought about this a lot in the past (trying to figure out what to do for my new house to support up to 100 amps in a pre wire situation). You are allowed to use SW cable at the 75c rating rather than 60c that NM cable is limited to, so that makes a huge difference.
The annoying part is that I have not been able to find any 3 AWG copper with just two hot conductors plus ground in SE wire. It is typically used for feeders to subpanels and so it generally always has a neutral. Also, it most commonly is used with aluminum wire not copper.
Now the big warning: DO NOT use aluminum wire into the Wall Connector. It is not rated for use with aluminum.
So with these factors at play, I have not found SE cable to recommend for wall connectors at 100a. Though now I am wondering if anyone makes 6awg SE wire with just two hots and a ground in copper?
