Because we want to send rockets to Mars? You know any other way to do it?
Sure. SpaceX uses LOX/RP-1 (i.e. Kerosene and Liquid Oxygen).
Thank you kindly.
they still are on SA. say the words Hydrogen is awful and Davewmart may report you and drop bricks on youEvery time I see "Hydrogen vs. Battery" in the new posts list I cringe a little bit and think to myself:
surely no one is still debating this...
If only battery manufacturers had the same lobbying power as oil companies... Can you imagine how much EV infrastructure we could have already?
Obvious dishonest claims in slide 9. Claim 1 minute gasoline fillip for 620 miles. Who can pump 15 gallons in one minute? Or does a Golf TDI get 60 mpg?For the German speakers here: http://www.mobilitaetstalk.de/htm/de/pdf/loescheter_horst_elektromobilitaet.pdf
This looks like a hit job on EVs from Volkswagen but they inadvertently confirm that hydrogen is a bad idea with the numbers on slide 42.
The title slide says it was given by the head of VW's research activities, but the metadata says it was written in 2012 by Dr Eva Schiesswohl, a young engineer there who did her PhD thesis on fuel cell cold start systems.
You show me a CAR (not a big-rig) that can accept 60 gallons a minute. As a former diesel driver I can tell you that those diesel pumps that can do 60 GPM are almost impossible to use on a light passenger vehicle, the nozzle barely fits in the vehicle and if you pull more than a quarter of the way on the trigger it just cuts off from the back-pressure.Gas pumps peak at 10 gallons a minute in the US. Diesel pumps can touch 60 gallons a minute. Taking on 30 gallons in 30 seconds is beautiful.
In fact, because of the way diesel foams as you fill, diesel cars take significantly longer to fill than gasoline ones.
I can GUARANTEE you've never put 30 gallons in in 30 seconds. If you filled at that rate until it cut off, you took on far far less than your tank capacity, and if you filled at a rate your vehicle could accept, you didn't take it on at that rate. (perhaps in the motorhome if it's a true motorcoach based on a bus or big-rig platform)My work pickups are diesel as was our motorhome. I've used them many times all across the USA.
75 gallons.I can GUARANTEE you've never put 30 gallons in in 30 seconds. If you filled at that rate until it cut off, you took on far far less than your tank capacity, and if you filled at a rate your vehicle could accept, you didn't take it on at that rate. (perhaps in the motorhome if it's a true motorcoach based on a bus or big-rig platform)
I'm not a hardcore evironmentalist, and if people want to make stupid decisions with their own money, that's not really my business.
But the big new is a hydrogen METAL room temperature superconducting battery.
Professor Silvera and his fellow scientist fellow Ranga Dias squeezed a sample of frozen hydrogen to nearly 72 million pounds per square inch, which is greater than the pressure at the center of the Earth.
They created the immense force using synthetic diamonds mounted opposite each other in a device known as a diamond anvil cell.
Except that as is continually pointed out, Hydrogen is a WORSE battery in every measurable way. It's hard to extract, it's extremely dangerous to store, it's extremely energy intensive. It's just not a good plan.Toyota might be right "hydrogen is the future." Not because it is better that batteries, but because it is a better battery.
Boy, that is some huge corner .... first, they haven't verified if they actually got solid H, and second they are just speculating on whether (a) solid H will survive room temperature and (b) whether it is a super conductor.I'm sure mass production is just around the corner.
You know what all H2 announcements, and all room temperature superconductor announcements have in common? They're always "just about there", but never quite at the point of being practical.Boy, that is some huge corner .... first, they haven't verified if they actually got solid H, and second they are just speculating on whether (a) solid H will survive room temperature and (b) whether it is a super conductor.
Still, a room temperature superconductor would make life much better.
