@eprosenx
Help me understand this snippet of NEC. Suppose I have an accurate history of my electricity usage. I do, thanks to my utility's website.
Let's use July of this year as an example. I consumed more electricity that month than any other over the past year. The weekend of 7/7-7/8 was a hot one. The Weather Underground almanac says temps were in the upper 90s. I was definitely using my 30-year old central AC system:
Looking at July 7th in particular, the worst hour of the day was at 4PM where I consumed 4.53 kWh:
I know it's not possible to determine *peak* loads from this data but if my math is correct, I averaged 4.53 kW consumption for that one hour, which at 240V equates to an average current of 18.875A. In fact, over the past two years the most electricity I've ever consumed over a 1-hour period is about 4.6kWh. That could have been on a hot weekend or on a hot weeknight after getting home from work and firing up the AC (which we never run during business hours on weekdays while we're at work).
I'm sure this 4.6 kWh number isn't a worst case scenario. The AC may be running but other goodies that use a lot of juice probably aren't (ie the Keurig, the toaster, the Instant Pot, the sous vide, my SO's hairdryer, etc). They probably *do* include my desktop PC and a 50" old school plasma TV, as well as the kitchen fridge and a small wine fridge that cycle on and off.
I suppose if I wanted to get really pessimistic about this I could simply turn on my AC and bottom out the thermostat ensuring it stays on steadily for over an hour, fire up a few appliances and then go back and look at the utility website again.
Can any of this data be used to determine actual loads that can be used to satisfy NEC?
