I got my MS in December and have been charging it in my garage where temps have often been below zero.
I don't have a dedicated meter for the charger, so my data is pretty bad, but I'm seeing lower efficiencies and thinking temperature may be a factor.
Looking forward to spring!
Cold weather strategy for my wife’s S100D, kept on the driveway. Near Philadelphia, we get stretches of below-freezing weather.
She typically does only local driving, wants comfort, not range. Time of Use metering not available.
Objective is to have a warm battery pack when she unplugs the car and sets out at some unpredictable time between 08:00 and 10:00.
Strategy is to set Max charge rate and start time so that car is still charging when she unplugs, yet finishes the day with at least 90 miles of range. Wife is uncomfortable with lower charge level. She never let her previous ICE cars go below 1/4 tank.
Set Max charge level about 260 miles. Set charge rate about 30 Amps. Start charging at 05:30.
If car is approaching Max charge, skip charging for a day or two. If it is well below freezing in the morning, start preheat at 07:00.
Could charge up to 72 Amps from HPWC on 100 Amp circuit. Only do that when aiming for full charge before a long drive. 2-gauge copper cable to main panel gets warm at full-rate charge.
BTW - resistance heat loss is pretty much the same for a given KWh charge, regardless of charge rate. You can get your wires pretty warm for a short time with high Amps, or leave them cool to the touch for a long time with low Amps. Power lost to resistance (heat) is Amps (amount of current) times Ohms (resistance). Unless you’re dealing with superconductors or extreme temperatures, resistance doesn’t vary with temperature.
Thus, cutting Amps in half means you cut power loss in half.
Multiply power by time to find energy loss.
Cut your Amps in half, you’ll have to charge twice as long to pack the same number of miles into your car’s battery.
Thus, lose half as much power in the wire, for twice as long, and you’ve lost the same amount of energy.
Thicker (lower gauge) cable to your charge point does save some money in the long run by lowering resistance. Less power lost in the cable, more delivered to the charger.
