Just wondering, lolachampcar, if you've got range mode on or not. Because the torque sleep improvements in efficiency with range mode on are supposed to be significantly better than with range mode off.
Early on, in the winter, I was wondering if torque sleep was working on my P85D, because my efficiency, as compared to EV Trip Planner, was worse than other people's. I think the bottom line is that at some power requirement, torque sleep just doesn't kick in, so for me, in the winter, with the cold, thick air, trips at 65 and 70 MPH were above that threshold all the time.
Now we're actually beating EV Trip Planner numbers pretty consistently. I've been tracking one set of trips regularly. These trips are about half highway and half rural country road, through some towns, etc. My wife drives at least two if not three times as many of these as I do. She sets the TACC to 68 on the highway, and probably never exceeds 70. I set the TACC to 70, and will occasionally do 75 or even a little faster to pass someone and get back out of the way of someone trying to pass me. But the vast majority of the highway driving is at 68-70, and that makes up more than half of all the driving time, with the other half being a mix that probably averages about 45 MPH overall. All that being said, including some bad weather (rain, fog, etc.) that definitely hurt efficiency we're now averaging about 285 Wh/mi, when we were easily 100 Wh/mi higher than that when it was really cold. Again, some of that is, of course, attributed to the cold directly. But I think some of it is due to torque sleep working now, when it wasn't working at the same speeds in the thicker air.
I really should do another side by side at night (no traffic) with the cruise at 78 with normal acceleration and such.
If you do, and if you can stomach it, it would be interesting to see what would happen if you also did one at, say, 68. If I'm correct, the P85D's efficiency will be significantly closer to the P85 at 68 than it is at 78 because I think at 78 you are above the torque sleep threshold, and torque sleep is just not kicking in. Since you drive at a higher speed than I do, this would explain why you're still seeing Wh/mi consistently above 300 and I'm (well, we're--me and my wife) are now seeing Wh/mi consistently below 300.
