Active heating is disabled with range mode on.
Even worse. What happens if the battery freezes? Could happen at extreme temps I would think.
Definitely. The question then becomes which is the side of caution? Range mode is certainly better from the standpoint of climate change, so should we err on that side? But if range mode takes 2% of the life of the battery pack, then we should probably err on that side. Or, given that Tesla gave us a switch for a reason, should we adjust based on our current circumstances? On what do we base that decision?
Thank you kindly.
Take for example the passive heating target,
For one thing the battery voltage depends on temperature. See... There isn't any way I know that the amount of chemical energy stored in the battery could be affected by its temperature.
One of these things is not like the other. The science behind climate change is settled and agreed by overwhelming majority of scientists. The inner workings of Tesla battery pack management and it's long term effects are complete mystery and full of wild conjecture and guessing. This topic should stay on point, mods please move any of these replies to the main climate change topic.
It's kind of like what I say to the climate change deniers: Let's assume for the sake of argument it is only conjecture, shouldn't we err on the side of caution? ...
One perspective asserts that range mode mode is detrimental to long-term battery life, and the burden of proof, in their view, is for someone to prove to them otherwise.
One perspective asserts that Tesla is smarter than this and feels the burden of proof is on the opposing perspective to demonstrate how range mode is more detrimental to battery life than "normal" mode.
The question I have is if it could damage our battery under certain use cases and Tesla knows this (who else would know better) then why not put one of those little information "i" icons next to the switch with the warning or information. The battery has an 8-year warranty so why not protect their exposure if this is fact?We don't know how this works, but we trust Tesla
vs
We know what it's doing, maybe not in all cases but enough cases, and it's not what you think it is.
See post #108 (frozen battery couldn't charge). Probably not warranty related but if you live in cold conditions this would be good to know from Tesla if true.Probably makes little difference to the warranty. The replacement threshold due to capacity loss is pretty large, although I don't remember off hand what it is. Now, it would suck to be an owner that's 1% above the replacement threshold, you can certainly be that guy though.
There are trips around here, even with the newly permitted superchargers, that become very difficult when you lose that much capacity.
The Model S doesn't use any extra energy if it's in 'Range Mode". It sets the battery temperature target higher. The energy heating the battery comes from the motor and inverter. It's waste heat that would otherwise be just lost. There is no energy used in Range Mode.
The downside is that it reduces the effectiveness of HVAC and also runs the battery warmer.
Don't see the downside of that, unless there is a reason not to run the batteries at the temperature that makes them give the most range.
So the rules being used in Range mode are i) don't heat the battery with useful energy, and ii) don't cool the battery with useful energy, unless absolutely necessary, that is, using the widest possible temperature limits.
I've been in a Model S during the summer with range mode on that let the drive unit or battery pack get into an overheat condition and then pretty much take all the cooling capability from the cabin and pump it into the drive unit/batter pack.
March 2015 P85D with 31K miles. Range mode has always been left on. When new, 90% was 227. 100% was 253. With 31K miles now 90% is 226 and 100% is 251.
Does this mean if I'd left range mode off I wouldn't have lost 1 or 2 miles of capacity???
No one knows except Tesla. What is your typical charging pattern? Limit/Rate/Supercharger?March 2015 P85D with 31K miles. Range mode has always been left on. When new, 90% was 227. 100% was 253. With 31K miles now 90% is 226 and 100% is 251.
That's pretty extreme, 50%. What do you usually drive it down to?Unless I'm on a long multiple supercharger trip, the car is pretty much stored around 50% SOC and then only charged right before I leave.
