Yeah...
It's a unibody frame plain and simple. They are simple A, B and C pillars, just like every other pickup truck on this earth has - with the exception of a unibody structure as opposed to the typical body on frame design. Here's a picture of an F150 aluminum body that sits on top of the ladder frame for example. Same A, B and C pillars:Yeah...
I think he's conflating monocoque.
Cybertruck was never going to have stressed side skin in the middle. So the 'delayed' line of thought makes no sense.
Here's the exoskeleton:
Structure on the outside, including rear load path.
Here's a unibody frame picture from a Honda RIdgeline:
But how is that functionally different than a unibody? And is it actually an exoskeleton?Here's the exoskeleton:
What Is a Monocoque Chassis? Pardon our French, but that means "single shell" or possibly "single hull" if talking about boats, which we're not. In monocoque structures, as with exoskeletal insects, the skin is structural, bearing tension and compression loads. It was a popular way to build airplanes in the early days, but most of today's aircraft augment their structural skins with some sort of internal framework, making them semi-monocoques. Few commercial road vehicles have ever used a true monocoque structure, but the racing world has embraced the form.
Yeah, I'd read those sites too.But how is that functionally different than a unibody? And is it actually an exoskeleton?
Body-on-Frame vs. Unibody vs. Monocoque: What’s the Difference?
A look at the history of vehicle structural design considering body on frame, unibody, monocoque, space frame, skateboard chassis, and other techniques.www.motortrend.com
But not much different than a unibody. Is there any reason a thicker skin couldn't also be attached to any conventional unibody?It's different than every other truck that has a ladder frame.
I agree that unibody and exoskeleton have overlap.But not much different than a unibody. Is there any reason a thicker skin couldn't also be attached to any conventional unibody?
Yah, but you asked about "conventional unibody"Sure you have to match material characteristics appropriately. Maybe the Cyber should be called uniskeleton, or exobody?
I was thinking in terms of design and not material. "Conventional unibody" can be made of steel, aluminum, or a combination of both, or even composite.Yah, but you asked about "conventional unibody"
So the "exoskeleton" is too stiff...I agree that unibody and exoskeleton have overlap.
The issue with using the 3mm stainless over a conventional body is that, large planar surfaces (especially creased ones) don't like to flex. Unless the substructure is equally rigid, the body deflects relative to the skin. That results in: shearing off of attachment points, flexure (oil can or creasing) of the skin, or that the skin is the load member.
Of course, the attachment points could be compliant like truck body to frame mounts, but that is bad from a dimensional control and/ or fatigue point of view.
For a conventional truck...So the "exoskeleton" is too stiff...
Doesn't matter, just let FSD drive.....Pretty large section of the windshield not being cleared by the wiper
That's not encouraging to me. A 10% energy density increase over the 1st gen 4680 packs at 244kwh/kg means it'll rise up to ~270wh/kg - roughly equivalent to the current 2170 packs. Even assuming a larger structural battery pack for the CT, I don't see a path toward a 500 mile range unless Tesla basically does the same thing as GM/RAM and goes with a 200+kw pack size. That would really increase the weight of the CT though. Anything is possible, but I've seen quite a few recent rumors that the initial CT launch is only going to include a 350 mile range dual motor CT - with the tri-motor model coming at a later time, perhaps 2025/2026 when the battery pack innovations promised at battery day actually come to fruition. Just my two cents of course.Drew’s comment on earnings call: Ready to start production of CYBERTRUCK cells, with 10% greater energy density than existing 4680. This meets their energy requirements for the cybertruck, anodes with silicon, and in-house cathode, will be coming another day.
GSp
244 and 270 Wh/kg are cell densities. Pack densities are much lower.That's not encouraging to me. A 10% energy density increase over the 1st gen 4680 packs at 244kwh/kg means it'll rise up to ~270wh/kg - roughly equivalent to the current 2170 packs.
