The volume/SA increases by ~ 17% in the larger cell if my arithmetic stands the test of timeand I reduced charge rate by 10% compared to S/X 75 because of surface/volume difference (I didn't try to calculate precisely, but should be close)
Its less than that at night.Your electricity's less than $0.02 per kWh?
Looking at Tesla's Charging page they estimate it would cost me around $11.50 to fully charge a Model S for 300 miles.
I thought the most recent, new 1860 in the Model S peak charges at 1.2Cyes, but my base case scenario that 2170 are simply bigger cells with almost identical chemistry to current 18650 and in such case 55 kWh pack should be able to charge at ~60-65kW level before taper which would be 30% faster than Bolt
Glad we know they are different chemistries based on comments by JB and Elon saying so.yes, but my base case scenario that 2170 are simply bigger cells with almost identical chemistry to current 18650 and in such case 55 kWh pack should be able to charge at ~60-65kW level before taper which would be 30% faster than Bolt
All else staying the same, that might imply the Model 3 peak charges at 1.2 * 0.833 = 1C
Then a 55 kWh pack might reach 55 kW
the Bolt reaches 45 kW IIRC
So the Model 3 would have a 55/45 = 22% advantage in peak charging speed.
I'll hope for more !
For my personal use I'll be happy with an average throughput of 60 kW until 80% charge and anything faster will be a treat.
You have a power contract?Aha - thanks for clarifying.
I'll have to review rate plans when my contract expires next June. Something like TXU's Free Nights and Solar Days might be nice as it'd be $0.00 to fill up; though, it might not be better overall as the daytime rate is higher and I work from home.
I'm sure you might be aware of this, but you can set a timer in your Tesla to start charging at a specific time.
Has anyone done the math when it's 94 degrees out and air conditioner is cranking like today or when it's 15 or 20 degrees like we sometimes gets in NJ and heater is on full blast. I have not seen anything written about thisI think there is a very good chance the base Model 3 has a lower EPA range than a Bolt. But the highway range will be higher.
The EPA range uses a combination of the city and highway tests and favors the city tests. The AC induction motor is more efficient than the PMAC at cruising around at steady speeds and much less efficient during acceleration and deceleration. So city tests favor the PMAC motors like those in pretty much every other EV, but highway cruising goes to the Tesla. Add in the effects of aerodynamics, and I think the Model 3 will have an easier time making Supercharger jumps when range really matters. But I think there is a very good chance the Bolt will carry the promotional headline figure.
There's nothing wrong with make a base version that's affordable to the masses and ones with highly desirable features that greatly improve profit margins. I see no reason to call that greed.The only logical reason to price it that way for Model 3 would be greed as it exceeds gross margins. The goal is to make this car affordable to the masses. A range near 300 mi will be highly desirable. They can either compete now, or drop the price significantly in two years as there will be competition and owners will be angry. They can still make their desired profit margins at $200 / kWh unless they are losing their butts on the car itself which is doubtful.
Alas, noYour electricity's less than $0.02 per kWh?
Two of the greatest hindrances to the adoption of EVs and sustainable transport in general are cost and range. Costs must decrease and range must increase.There's nothing wrong with make a base version that's affordable to the masses and ones with highly desirable features that greatly improve profit margins. I see no reason to call that greed.
This is because they kept breaking... They simply took out the second gear and thus limited top speed. It had nothing to do with the inverter. Going to a single speed gearbox was never the desired outcome. It was just simpler then having it break.The first Roadsters "had/required" two forward gears not any more.
July 28, 2017 actually will be the first car, right?The old 18650 cell format was much shorter and skinnier than the Model 3 2170 cells. While Elon said these 2170 cells have the highest energy density they have only been put into a single known car at this point.
They also have to make the company profitable and survive. As for the target market, it's very clear it's the BMW 3 series and Audi A4. This ranges from $33k up to $90k for a loaded M3. Tesla was never targeting the econobox market. They are leaving that for the other automakers.Two of the greatest hindrances to the adoption of EVs and sustainable transport in general are cost and range. Costs must decrease and range must increase.
If they price the one model that has range comparable to many ICEs outside of the target market then that is not really the quickest way to achieve their mission statement of accelerating the the world's transition to sustainable transport.
The base model still has a limited range compared to typical ICEs. Profitability is still achieved at the same or even slightly increased margins... 30% say or even 40% but why must it be several hundred percent like it is now with Model S?They also have to make the company profitable and survive. As for the target market, it's very clear it's the BMW 3 series and Audi A4. This ranges from $33k up to $90k for a loaded M3.
Also, I'm not seeing how having more expensive higher end options conflict with the mission. The people who can't afford it can buy the base model.
