I assumed a 60 for the base Model 3. If it turns out to be 55 KW, the car consumes less juice to hit the goal of 218 miles: about 250 w/hr per mile. That seems on the low side of likely, but not impossible by any stretch. Especially highway miles. Robin
I see that your calculation is 55,000Wh/218mi= 252Wh/mi. Starting with Wh/mi numbers to guess the battery size of the Model 3 is an interesting strategy but real world Wh/mi numbers that people talk about are not based on EPA rated range because EPA-rated range is a little optimistic than real world range. Also rated battery capacity is higher than actual available capacity.
For example, let's take the original Model S 60. It had 208 mi EPA rated range, the battery size was known as 60 kWh. Based on these two numbers, efficiency should be 60,000Wh/208 miles= 288 Wh/mi. However, the real world range is less than 208 mi and the usable capacity is 58.5 kWh.
In fact, if you look at the survey data around cell V80
here, it shows that the S60 has 313.8 Wh/mi average efficiency. That's worse than what you calculated. It means 58,500/313,8= 186 miles average real world range for the S60.
Similarly, if we use EPA rated range and rated battery capacity, the S85 efficiency would look like 85,000Wh/265mi= 321 Wh/mi. However, the 85 kWh battery has 77.5 kWh usable capacity (
source) and the average real world range is less than 265 miles. The survey data shows 342.7 Wh/mi. That means 77,500Wh/342.7 Wh/mi= 226 miles average real world range for the S85.
Some people might argue that the EPA rated range system is the perfect rating system. Tesla disagrees. That's why in Europe they have invented a completely new range unit called Typical range. Tesla cars outside North America don't display EPA rated range. It is not a selectable option in the settings. Instead, they display Typical range which can be set to km or miles as usual. The most interesting thing about Typical range is the fact that it is less than EPA rated range. For example, the S85's in the UK display 249 miles Typical range instead of 265 mi EPA rated range in the USA. Of course, even Tesla's Typical range is slightly optimistic (9% over real world average) but it is less optimistic than EPA rated range (15% over real world average).
Troy, no, I meant the M3's range and the M3's pack. Which (as far as I know) might be rated 55 or 60 KW. Has it been announced as one or the other yet?
No, it is still unclear whether it will be 55 or 60 kWh. I think with the version you have added, I'm now counting 4 different theories for the base model:
Theory 1. 55 kWh battery with 215-220 mi EPA rated range.
Theory 2. Software limited 55 kWh (actual 60) battery with 215-220 mi EPA rated range.
Theory 3. 60 kWh battery with 235-240 mi EPA rated range.
Theory 4. 60 kWh battery with 215-220 mi EPA rated range.
I don't think Theory 4 is technically possible. The Model 3 can't have a 60 kWh battery and a range less than 230 miles at the same time because:
- At 2.36 m^2, the Model 3 frontal area is 2.9% smaller than the Model S frontal area at 2.43 m^2.
- Model 3 drag coefficient is expected to be 0.21 based on Elon's tweet here vs 0.24 for the Model S. That's 12.5% better.
- If there was a Model 3 60, its weight should be 1,746 kg based on my calculation vs 1,961 kg for the Model S 60. That's 11% less.
Update: I think the Model 3 55 will have 54,120Wh/196 mi= 276 Wh/mi average real world efficiency.
