Is this the new HPWC?
Discussion in 'Model S: Battery & Charging' started by Linux64, Jun 26, 2013.
  1. Linux64
    Linux64 Member
    Utah
    It arrived from Tesla last week. There was a wall hanger included in the box.
    Just curious is this already has the upgraded components I read about?
  2. mitch672
    mitch672 Active Member
    Stoughton, MA
    Sure looks like the new version because the fuses are mounted horizontally, the older version had them mounted vertically.
  3. TurboFroggy
    TurboFroggy Member
    Everett, WA
    Yes this is the new version, you should be good to go for 80 amps.
  4. pilotSteve
    pilotSteve Active Member
    Vancouver WA
    When you get it installed please post if you still get the "limited to 60A" when charging. I wonder if there is anything in the pilot signal from the HPWC that tells the Tesla its a new version and good to go at 80A, or if this message appears (and will continue to appear until ????) with ALL 80A capable chargers.
  5. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    The HPWC uses J1772 standard signaling. There is no way for the car to tell if it's a J1772 or HPWC. In fact I had been getting that annoying message on 70 and 80 amp J1772 stations until the recent firmware update.
  6. lolachampcar
    lolachampcar Active Member
    WPB Florida
    I doubt it.... I (was) using an OpenEVSE with standard 1772 protocol and always had to over ride the 60A nag message.
  7. pilotSteve
    Vancouver WA
    Reminds me of the old Heinlein quote "I shot an error into the air and it landed everywhere".
    So whats likely to be the final solution? Tesla decides that "all" old HPWC have been upgraded (or at least shipped their kit) and a future firmware rev restores the original (and proper) limit?
  8. Doug_G
    Ottawa, Canada
    I've not been getting the message at all with firmware 4.5, so it appears they have already changed it back. Or maybe made it smarter so it remembers if you override it.
  9. lolachampcar
    WPB Florida
    Nice to hear it is gone in 4.5. I was a little curious when it did not remember my updated settings.
  10. mitch672
    Stoughton, MA
    Not true for me. Gets set back to 60A, I override it back to 75A, but because I'm using the timer, at 7:00AM when it starts charging, it's back to 60A. Really frustrating that they insist on this "nannying". If you override it once at a particular location, it should remember that and NOT keep lowering to 60A
    I don't even use a HPWC
  11. FlasherZ
    Have you gotten the latest 4.5 update (last few days)?
  12. mitch672
    Stoughton, MA
    Not yet, still have v4.5 (1.33.48)
  13. achaar
    achaar Member
    DC metro
    So I got this same one, and had it installed a couple of days ago (car comes on Saturday). The instructions said to hook it to a 100A circuit. Are you saying it will only use 75 (or 60)?
  14. FlasherZ
    I still have 1.33.44. :)
    So it seems like a later version remembers if you've done the overriding (if you have a fixed HPWC), but we may not have it yet.
    - - - Updated - - -
    When you charge an EV, it is considered a "continuous load". By NEC (electrical code) rule, unless you have specially certified infrastructure (which pretty much no one has), the circuit must be sized and rated for 125% of the continuous load. As a result, you need a 100A circuit for an 80A continuous charging load, which is what the HPWC will deliver at maximum current.
  15. cinergi
    cinergi Active Member
    MA
    Mine (1.33.54) is NOT remembering that I override the 60 amp setting. I'll ask ownership ...
  16. MBCMDR
    MBCMDR Member
    Fairhaven WA
    After do the installation of my HPWC I still get the max charge of 63A, I hope the next software bump will boot this back up to 80A rate..
