gimp_dad
Can you charge at 24A on 120V?
I'll try it with my adapter as soon as I am near a 30A outlet. My car is Aug 4, 2012 so I am guessing it will not work.
Yes, but here's what the guy in Canada got with his 3 week old car:
Here's the problem with trying to go over 20A @ 120V:
The single hot line of 120V is only rated at 20A. You put two together to get 240V@40A. If you're pushing a single 30A hot leg through the UMC's internal relay and wiring, you're going to have a bad time.
If the UMC was rated for 60A, I could see it working.
None of what you wrote is correct. First, we are talking about 120v sources that are rated for 30A. Second, we aren't putting two 120v sources together. Third, even if we were, you wouldn't be doubling the amps.
There's so much wrong with what you've written it's hard to know where to start. The TT-30 has one 30a hot conductor, not two smaller ones. When connecting it to the UMC you connect the single hot and the neutral to make a 120v 30a circuit. The UMC has conductors sized for 240v @ 40a and they can easily carry 120v @ 30a. The limiting factor seems obviously to be that the car won't use both chargers @ 120v.So how are you taking a TT-30 connection (that historically has a 20A and 10A from the same phase) and running them through the UMC? Surely, you aren't running the 20A down one side and the 10A down the other. It wouldn't complete the circuit since there is no neutral used.
To accomplish 120V charging, the Tesla NEMA 5-15 and 5-20 adapters connect the ungrounded ("hot") conductor to one of the line power inputs and the grounded ("neutral") conductor to the other line power input. So yes, for 120V, it uses neutral.
it is on a 20a breaker. I took a picture and stopped it there. I would like to go to 30a at 120v because some campgrounds do not have 240v but have 30a 120cv plugs.
Come to think of it, if you want to test it just cap off one of the hots in the 14-50 outlet and swing the neutral over to it. You'll get 50A @ 120V to play with and see just how high it can go.
