I've had one map update in over two years of ownership of my Model S. I wouldn't worry about it very much.
How did you know a map update was available or that it was update?
I had an alert on my display.How did you know a map update was available or that it was update?
Im pretty sure its a timer related issue on the App by now. If you connect before the timer expires it will work. If there has been no activity on the app (and hence the associated port) the router must be terminating the connection over that port by closing the port. The next time you see this problem over wifi, could you try to terminate/close the Tesla App and restart it to see if it reopens the same or different port and tries to connect to the Tesla Server and therefore the X. Often the phone OS also does something like this for background services especially on iOS. A good way to reproduce this issue might be to let the app be onnected over Wifi overnight and try to access the X first thing in the morning.Felt like attempting to connect wifi and it worked, sometimes it works and sometimes it doesn't. Hopefully when my X leaves and returns home the connection will remain.
It seems that a new firmware update came out? Is that correct
If you are on Android you would need to terminate the background service, killing the app wont suffice.
Good news! I went for a drive came back the car connected to the wifi and the app still works!!! Perhaps forwarding port 22 did the trick? Hopefully the issue has been resolved.
Let me guess. Android?Update: actually it worked after letting the app wake the car for a minute even though I have always connected check and energy saver off
Our iOS devices connect immediately but not so for the Android phone.
You are holding it wrong, that's the actual reason for all this app connectivity shenanigans.Android.... noooo!!! (sorry android users, I am an Apple person)
iPhone 6 user
Please turn off DHCP on you Garage airport express, this will allow the AirPort Extreme to be the only router to serve the car an IP address, what you are experiencing sounds like an IP conflict.Felt like attempting to connect wifi and it worked, sometimes it works and sometimes it doesn't. Hopefully when my X leaves and returns home the connection will remain.
I think the Tesla sun shade has a compatibility mode to allow Apple routers to work with the car. Have you tried installing the sun shade to see if it helps?
I can't tell if you're joking or you really do have inside information. I'm pretty sure it's the former, but I could totally see Elon doing this as a surprise. Tesla monitors the forums pretty closely - I'm sure they know who the sunshade captain is.@K-MTG Congrats on getting your X. I am sure all the teething problems will sort out soon. I heard through reliable sources that your sunshade is waiting on Elon's desk for his personal autograph. Apparently they have Elon's photo printed on your sunshade as a token of appreciation for you
yeah... it's only $250 to xpel the keyfob...Or you can simply get XPel/Opticoat for the key fob. All the cool kids are doing it.
