AmpedRealtor
New isn't always better. The Model S LED lights suck hard, apparently, and Tesla has done nothing to remedy this design flaw. A lot of things about Model S need to "get with the times".
Thanks, FS911, I thought i had no real options for the LEDs in my car and i was right! I await a good bolt-on replacement solution....No upgrade that I know of for the OEM LED headlights from Tesla... they are a proprietary design.
If you have the original HID headlights from Tesla... found on the Model S from 2012 to mid-2016:
- You can try the aftermarket LED kit that Tension suggested, however, the output will be low.
- I would recommend an upgraded HID kit that will overdrive new bulbs at 55W vs. 35W OEM.
- 50% more lumens and better night visibility with the Teala OEM projector lens system.
Tesla led-hid emulator Connect Led Headlight To Hid Version | eBayThanks, FS911, I thought i had no real options for the LEDs in my car and i was right! I await a good bolt-on replacement solution....
If you do facelift upgrade and you want headlights match you need thatI agree completely... the LED headlights are very poorly rated.
Why would you want to downgrade to LED headlights (2018-2019) from the original Tesla Model S with HID lights(2012-2017)?
Yes, everything will work.Are all functions enabled by this emulator, e.g. on/off depending on the settings in the car? Cornering lights when turning the steering wheel? Leveling according to load in the back avoiding blinding others?
Appreciate the input since I already bought a set of led headlights to retrofit, but not sure which path to take on the installation/integration...
If a-t-il all possible, could you reference to where I could purchase such a kit and detail somehow what should I expect from the <overdrive > qualifier. I’ve got a HID that intermittent on our November 2013 model s and am puzzled as to what to buy. So far I’m tempted by these:
Philips D3S Standard Authentic Xenon HID Headlight Bulb, 1 Pack
Or
RCP D3S 6000K Xenon HID Replacement Bulb Diamond White Metal Stents Base 12V Car Headlight Lamps Head Lights 35W, 1 Pair https://www.amazon.ca/dp/B01KSTL06U/ref=cm_sw_r_cp_api_i_n7u6DbNG500GH
Also something to consider, now that we have the perspective of time - the original headlights hold up way better than the newer ones. I have a 2015 Model S on its original headlights, as bright as new, and a 2018 Model S already on its second set of headlights.FYI in case anyone's thinking about upgrading nosecone cars' headlights, here's my post on the subject [pics] Upgraded factory projector HIDs to aftermarket Laser projectors
