But the EPA doc says 188 kw for the rear AWD motor.
Which is impossible at 350v and 500 amps (as the rumor claims)... 350v at 500 amps only gets you 175 kw.
On the other hand....
Tesla Model 3 gets hacked, reveals more details and great potential for dual motor/ performance versions
This says 400w mav voltage for battery and 1200A max discharge for the battery, max discharge 370 kw.
400v at 500 amps is 200 kw
The EPA doc says 211 rear/147 front on the P, 211 rear on the RWD, and 188 rear/147 front on the AWD for kw (AC 3 phase)
Based on 400v then 358kw on P only needs 895 amps total- way short of the 1200 it's capable of...527.5 total amps to make 211kw on RWD, and 837.5 amps to make 335kw on AWD
That front motor giving you 147kw on both AWD and P-AWD can manage that with 367.5 amps at 400v...
This leaves quite a bit of headroom in all 3 models for a future uncorking if there is one.
Bumping the rear motor to 800 amps gets you 320kw just on the rear motor (and would bump HP up to 429 on the RWD) for example
Course this assumes no losses anywhere...and the DC power is inverting into a 3 phase AC motor....
