May update:
Lifetime:
26,453.8 miles
9,131.1 kWh
345 Wh/mi
Month:
Car : 2,127.9 miles
Car: 651.3 kWh
Car: 306 Wh/mi
May Actual energy: 785.7 kWh
May Actual Wh/mi: 369.2
So my quick math shows that comes out to ~17% losses due to charging inefficiency. That seems reasonable but higher than numbers I've heard reported elsewhere from Tesla and others on this site (more in the 8-12% range for charging loses), though I haven't seen a ton of actual data on the subject. Any insight you've gained from looking at these numbers?
My interest in all of this is simply to try and calculate what comes out of the wall (and hence, what I pay for) that is directly attributed to the car. The trip meter does a pretty good job of reporting what comes out of the battery and makes its way to the road, but I believe they should also have a register that shows what went in via the charge port. I do this with a dedicated meter on my EV circuit and a spreadsheet where I track my public charger use.
Some of this may be attributable to pre-heating the car on shore power, but I didn't do this at all in May. I drive daily and my car doesn't sit around for long periods so, if anything, the "Vampire" losses should be lower in my use case.
A secondary point to my posting this information is to educate people to the fact that the car is actually "using" more electricity than the trip meter reports. If you had a gasoline car with a slow leak in the gas tank, you'd still consider what you paid at the pump, not just the leftover gas that the car burned.
Oy, @MichaelS, 278 Wh/mile is an incredible number for a 60 that was produced the same week and is in service in the same area as that of @Kipernicus's, @hans's and mine. We are struggling to come down to 300 and are hovering in the 308-309 range.
