The difference between my wife's coil and my Standard Air (that has been lowered just a bit with links) is between a 1/2" and 3/4" depending upon which corner your looking at. The difference between Standard and Low on my car is around an inch to an inch and a quarter.
Given that you're not going to be able to raise the car to get around issues, I would think one inch down from stock coil heights would be a good place to start.
WRT fitting everything, it is a PITA. I was hoping to get the upper spring perches from Tesla but learned you have to buy whole damper assemblies ($550 each). I then learned the two coil springs I thought I was ordering last week (where I expected an $80 price tag) turned out to be a full front and rear damper assembly. Ooops!
I've found some M5 adjustable upper perches/plates that have a urethane isolation bushing (like stock) for $300 each including 2.5" spring perches. Another option would be stock M5 units that do not have the fancy and not needed adjustability for about $80 each but they are designed to work with the stock BMW M5 large diameter coil springs. Nothing is turning out to be cheap or easy for a 2.5" conversion.
I guess I will know more when I get my two damper assemblies (for a whopping $1100).
Thanks for the coil spring numbers. They look a lot like my wife's which is comforting.
BTW, those look like 12" by 2.5" springs. Do you remember the rate and can you share the application?
