Just picked it up. They were out of chrome underlines so it's not badged yet. They're on backorder. Go figure
I drove from Fremont to Santa Clara. First thing I wanted to do was verify there wasn't an issue with range as I immediately noticed that the steering wheel is very slightly off center when it wasn't before. They didn't disconnect the Blackvue, so I'll probably go watch the test drive to make nothing happened. I'm more suspicious that removing and installing the battery could change the chassis alignment just slightly as the battery is a major supporting stress member of the car. It was cold and windy so I can't conclude yet that the high wh / mile reading I got on the trip back to work is really related to the upgrade or just non optimal conditions for good economy.
The battery showed regen limited the entire time on the way back which means it never warmed up. I jumped on the accelerator once right before getting to work and the meter went up the second 0 on the 400 which is where I'm used to seeing it normally but that's probalby when the battery is warm.
I'll grab my ipad and log the actual power draw when I do a more thorough test drive over lunch. I don't want to use max battery power yet. I want to see how much power I can draw by driving it hard and warming up the battery the way I normally do.
A full vbox performance comparison before and after may be forthcoming tomorrow but holiday travel plans may prevent that until after the 26th.
So upshot is no new information. I just created an empty post
