bradbissell
I had the first serious issue with freezing handles this morning. They have been hard to open on cold days, but not this this. Luckily the windows didn’t freeze in the upper position. I had to force the rear handle open to let my daughter in to the car get her to the bus. It was 27F and hadn’t rained in 2 days. There was ice in the rear door handle enclosure which I discovered after I forced the handle open. It appears that ice will form behind the door handle due to the angle of the enclosure. There appears to be no holes to remove water and the angle is opposite to which would allow water to run out.
To all those assuming that this isn’t an issue I can officially state (and yes i’ll play this card, as a NASA engineer) that this is an issue.
The doors will freeze and not for the normal reasons. I’ve leased a Chevy Volt which would freeze shut if there was heavy freezing rain, but not like this. Even the slightest rain days before will freeze the handles shut.
Elon, or your very capable engineers, please figure this out. It’s going to be a long 9 years owning this car in a cold climate if you don’t.
