Thanks for the tip! There have been several posters who would have been better off with an AL capable outlet, too!I am surprised that no one mentioned the 14-50 Hubbell outlet RR450F. It is their “Trade Select” residential version and it is sold on Amazon for < $15. Its design is very similar to their commercial HBL9450A, which is much more expensive. The main difference between the two outlets is that the RR450F was designed for Copper and Aluminum wiring and the HBL9450A is for copper wires only. So the HBL9450A wire clamp is made of copper and the RR450F wire clam is made of aluminum. Both contact material is made of copper as stated on their data sheets but I believe they are actually made of Beryllium Copper, which adds the springing action to the contact. Also, the HBL9450A is slightly larger and heavier and it requires a special plate cover as everyone noted.
https://hubbellcdn.com/specsheet/WIRING_HBL9450A_spec.pdf
https://hubbellcdn.com/specsheet/WIRING_RR450F_spec.pdf
After using the cheap HD Leviton outlet for about 28 month, it started to overheat and reduce the charging current to 16A so I decided to replace the outlet with this Hubbell RR450F, which looks ten times better than the Leviton or other similar outlets. I was surprised that it lasted that long as I am in Phoenix AZ and my Garage temperature in the summer gets to 120-130 degrees practically every day. After I removed completely the outlet and looked at the wires, I could see that the terminal screw was only clamping 3 or 4 strands of 7 strands wire. The other 3 or 4 strands were simply pushed away from the screw without any contact pressure. Basically, you would end up with double the contact resistance in comparison if all 7 strands were tightly clamped. No wonder these outlet catch on fire, it is just a matter of time, and how tightly the crew terminal was initially tightened.
View attachment 792982View attachment 792983View attachment 792984View attachment 792985
What is the brand/model of the power meter to the right? I don't think I'd buy one since I already have the monitors in the car, but it looks like an interesting bit of hardware.
