davewill
But I assume it's located where a dryer would be, and if anyone ever wants to use it for a dryer, it would need to stay a 10-30. If you change it, you could end up in an awkward situation where you need to change it back, but can't as code doesn't allow installation of a new 10-30. Besides EV charging-wise, there's no downside to leaving it a 10-30. I'm certain that they can find an adequate 10-30 replacement.Do you still need to use it for a dryer though? If not, then it wouldn't really need to stay as a 10-30. I get why you are saying it can't go to 14-30 if you don't have the extra wire that a 14-30 would require, but the substitute for a 240V only outlet that an EV charging connection would need is a 6-30. It is only three wires and is just Hot1, Hot2, and ground, and you could switch to that from the wire that the 10-30 already has there.
