Autozoeker
2023 MY LR Cherry Red
@OneOhEd 449km for 90% is pretty normal, I have it to.
See more dutch owners numbers here: Typical Range bij 90% laden
Yup - that's what I got from day 1. Unfortunately now I get about 440 and it usually drop to 438 when I enter the car (or very briefly after). Then I loose more km's no matter how gently I drive. I simply cannot believe this is regular behaviour.
Thanks for the link - I'll check it out.
I have a Model 3 performance. I commute approximately 40 miles back and forth to work every day. I take a different path home than to work. going to work . i have had usage as low as 195. Going home, my usage has never been below 275. What gives? Well, going to work is "generally" downhill, and going home is obviously "generally" up hill.
I also noticed a MUCH larger usage of energy when it was raining... like MUCH more. All of these things effect gas cars too but since people have all this data on their BEVs and focus on the mileage number, it seems like more.
Reading the list of complaints you put there, I would imagine that tesla could address a few of them, but would not be able to address others... and depending on how you approached them, they may have just decided that you would not be happy and stopped trying to help you. Note, I am not blaming you or anything... it might sound like that but I am not. I am just saying that, as a person who has spent a lifetime in one form of customer service (or customer service management), anyone who has ever had to "help customers" for a living understands there are sometimes people you will not be able to make happy.
Heck, you mention you are a consultant. I am sure in your job, there are some customers you have come across that you consider "unreasonable". I am sure THEY dont consider themselves unreasonable, but I would imagine that if you have spent any time at all as a consultant, you came across customers you either considered unreasonable or "fired" as your clients, because no matter what you did they were not happy. Some of their complaints might have been valid, but either they were not delivered in a respectful manner, or they were mixed in with other things you KNEW there was nothing you could do about... and you also KNEW that they were not going to let you fix the things you could fix, and ignore the things you couldnt.
My advice to you would be to focus on the things that they might be able to address (brake noise, paint defects) and let go things they will be able to do NOTHING about (small mileage loss, complaints about "losing too much KMs when driving gently"). There are waaay too many factors that drive how much energy the car uses to get moving... road surface, topology, wind, acceleration, etc.. they will be able to do nothing about that, and if you focus on that, you will get nowhere AND get your real complaints ignored.
#unsolicitedadviceover
It even had food leftovers inside it. Foul....
Sorry - it's bad... it's REALLY bad
I charged my dual motor LR 3 to 90% today and it showed 255 miles. That seems pretty terrible.
I also have an AWD. My lowest so far is about 256. But it's been hitting 260 for the past week or two...
10% range loss seems pretty catastrophic for one year of regular driving. @StellarRat I specifically bought a Tesla because they are supposed to have the best battery longevity.
I guess I will run it down to 10% a couple of times and back up to 90 then do a full charge and see what it shows.
I don't charge it every day and charge it at work for 2-4 hours every 2-3 days to take it back to 80-90%, perhaps the cells are unbalanced.
I can only go by my own experience, in which I plug in every time my car hits my garage, and charge to 90%, and do not have a single mile of rated range loss. Its still 279 on my model 3P, and this is after 13.5k miles and 9 ish months..
One constant in almost all of these threads is that, for the most part, people who "dont charge every day" show some rated range loss. I can only go by my own experience, in which I plug in every time my car hits my garage, and charge to 90%, and do not have a single mile of rated range loss. Its still 279 on my model 3P, and this is after 13.5k miles and 9 ish months..
also it does not appear that the "run it down and charge it back to 100" works as much as "set charge percentage to 90%. plug in every day, and do that for a week and then check), does.
Please remember that temperature affects the charge numbers. I've noticed more than a 15 mile difference since fall has arrived. It went down right in sync with the night time temperatures dropping about 20 degrees.
Mine have dropped at the start of Fall two years running now and then come back in the summer. The thing is that my car is done charging by about 11 or 12 at night but that is not the coldest part of the evening, so by early morning what was once a 227 mile charge is down to 221 miles (roughly) because the battery has cooled further. In the summer the opposite happens, the car is cooler at night and as the air warms in early morning the range increases slightly. My 227 mile charge is 236 miles by morning.In my case I experienced 0 loss all winter with temperatures well below freezing and all my losses were in summer at peak temperature. Temperatures are just now starting to drop and I've recovered 1 or 1.5% since my low a couple of weeks ago.
