Thanks for the feedback. How long were you using it till the adapter failed? At the moment I've been using the Rocketek adapter with a Samsung PRO Endurance 128GB card since mid-July. This setup has been solid but it just started getting super cold here. Will see if it lasts. Thankfully the adapter is under $10 if it does indeed fail.
Buy both. Do exhaustive testing with video and keep a journal. Report back your results to the forum.About to order, and can't decide between these two:
https://www.amazon.com/dp/B07B984HJ...olid=2XUWJBFW4IJST&psc=1&ref_=lv_ov_lig_dp_it
https://www.amazon.com/dp/B07NY23WB...olid=2XUWJBFW4IJST&psc=1&ref_=lv_ov_lig_dp_it
Which should I get?![]()
I've had the Samsung 32 gb one for a while now and have had no issue. I've heard mixed responses about the 64 gb or higher samsung cards and how it works for some people on their Tesla and how it doesn't for others, something about not being able to format to fat32About to order, and can't decide between these two:
I review the captures via Win 10 PC using:
1) 3 view Tesla Cam Viewer in a browser (by TMC member here)
2) VLC
3) Win 10 Media Player.
This has been my second Samsung FIT only larger capacity & this has been first time I've gotten the green captures.
Wondering if SSD drive would solve this or will a trip to service center.
To be fair to Tesla I dont think you can really blame them for this. There are two parameters that can make a drive fail, neither of which are controlled by Tesla. The first is sustained write speed. Most flash drive makers WAY overstate this; you are better off measuring this yourself. If you dont have a fast enough drive, then it will fail fast and the car will tell you.
The second parameter is worst-case latency, and is far harder to quantify. Basically, flash drives have internal housekeeping they have to do from time to time (including thermal throttling). This can result in the drive "pausing" data writes for some period of time. During this time the car has to buffer the incoming video in memory until the drive starts accepting writes again. These drive pauses are all over the place; some drives use lots of short pauses, others use fewer but longer pauses. But regardless, if the internal videos buffers in the car fill up while the drive is paused, then video is going to get lost, since the car has no place to store it. It's this second (and very unpredictable) parameter that makes so many drives fail, since often it will not show up initially (for example, until the drive has to handle wear leveling and/or block reclamation).
Ideally, Tesla would run some sort of test on a drive to validate it, but this test cannot easily detect pause issues, since the car has no way to know how to trigger such a pause, or how long it would have to test the drive before such a pause occurred (it might be weeks).
Those with long-ish memories may recall hard drives had a similar problem years ago. At that time they would occasionally pause to do thermal recalibration (as they heated up from a power-up). This was fine until people started streaming video, which needed sustained read performance, and the pauses would glitch the video. Makers worked around this with a new generation of drives that did continuous thermal adjustments to avoid the long pauses.
Except
Go back through this thread and read the posts from @Knightshade - he has done an excellent job of spelling out a lot of good info on this.
- There has been a notable surge of this issue with the V10 SW update
- It has happened with all types of devices (thumb drives, SD/Micro SD with USB adapters, and to a lesser extent SSDs) from a wide range of manufacturers.
- Tesla has communicated NO specification recommendations for what works best or "minimum requirements" (at least that I have ever seen)
Either will do the job, I had both, returned the Samsung (thinking it had faulted - it hadn't) and now using the Sandisk, benefit of Sandisk much cheaper but much less warranty, if you want the 5 year warranty and probably a better drive overall go for the Samsung, that would be my guess and was my choice initially.About to order, and can't decide between these two:
I mentioned this to the tech when I dropped off my car with them the other day. Telling us a 4 MB/s write spec without stating the conditions is pointless. The write speed of a drive varies with the manner in which the data is written. I use a program called FlashBench which measures write and read speeds with many block sizes. The write speed can vary from over 20 MB/s with 16 MB blocks to less than 1 MB/s at a 1 kB block size. So which number should I focus on? The data sheet says 5 MB/s.
This is not a problem unique to the Tesla dash cam. Every video camera has to do the same things Tesla is doing. It's not rocket science. In fact there are ratings intended to deal with this problem, Class and UHS. So why doesn't Tesla specify one of these ratings for this??? The industry had dealt with this problem in recording videos. Why doesn't Tesla get on board?
I used two different drives. One is a USB stick another is marco SD card. Both failed after a few weeks. I guess, the problem is not the drive but TeslaCam. For example I noticed my USB drive usually failed after I got into car at home or after work. These are the locations I don't have sentry Cam on. My guess is when I turn off car TeslaCam at location without sentrycam such as home that disconnect power to the USB and sudden loss of connection killed drives.
From reading this thread, USB stick drives are bound to fail. They are not designed for the massive read/write speeds and cycles that dash cams require. SD cards are designed for such operations and will be faster and more durable.
Read more of it
For one, there's effectively no reads happening with the dash cam.
And the write speeds needed are not massive in the slightest for the Tesla version.
As to cycles- flash memory is flash memory.
Cheap SDcards and cheap USB sticks are functionally the same thing.
The more expensive endurance type flashis "better" in the sense they'll last ~20-30 years instead of 5-10 for the amount of data Tesla writes, but that's about it.
There's bunches of threads at this point- and folks have had issues with USB keys, SDcards, SSDs....basically every possible bit of HW.
Because it's a software problem, not a hardware one.
Most likely because USB Sticks are much cheaper and are more likely to be in more cars. I speculate that the failure percentage of sticks is about the same percentage of failure for SD and SSD.I have read it, and it sure seems there are greater issues with USB stick drives.
Because its most likely a SW issue (see below)I'm not doubting you, but why do some SD cards work well, where others do not?
Having a bug in the software doesn't mean that ALL drives are doomed to fail, just that it is most likely the biggest contributing factor. If all drives failed, it would be an easier problem to diagnose and fix. Intermittent problems (be it in software, electrical, mechanical) are the hardest to diagnose and fix.If it were a software problem, wouldn't it be universal?
But because the only universal detail is the car's software, that is what points to that as the culprit.
So, when experiencing apparently random failures, the culprit is likely to be the non-random universal software and not the random USB devices being used?
I agree, and mentioned that if Tesla do have special needs they should probably at the least specify a “recommended drives” list of ones they have tested. Not perfect, but it would remove the guesswork. I was pointing out that (a) it will never work with ALL drives (despite others assertions) since there are stricter requirement than a normal “copy a file on demand” computer need, and (b) unlike other systems (including dedicated dash cams) the Tesla computer has to deal with other more mission-critical tasks which makes the balancing act more difficult.
I have no proof, as I have no access to the Tesla software stack, but I bet that Dashcam is pretty low in the priority list of the cars subsystems; if the car needs to worry about steering/safety etc, than dash am will get a back seat and this may cause the buffering issues that we are seeing. In that case any fixes may be probabilistic; they will reduce the incidence of this fault, but never entirely eliminate it.
I personally have never seen this issue even with a cheap USB sandisk drive (though I recently switched to an SSD for unrelated reasons). My car is HW3, and I wonder if the faster CPU in HW3 has indeed reduced the probability of seeing this, and if the issue shows up more on older HW versions. But this is speculation on my part.
