Very tired of this & expensive.
Might have to ping Elon & Co on why this is happening.
Dude, dont let him ruin ur day. He attacked on my post saying all usb sticks (even the very worst one) will work and last for a long time using his facts... The best we can do is continue our great discussion and ignore those nonsense.
The flash drive must have a sustained write speed of at least 4 MB/s. A sustained write speed is different from the peak write speed. Check the product details of your flash drive for more information.
Another good site for TeslaCam info:
Tesla Dashcam Advice, Recommendations and more! – TeslaTap's Dashcam Guide
Your link said:The Tesla dashcam stores about 3 GB of data in an hour in one-minute segments
Your link said:To write four 720p video files, the drive must handle 16 MB/s or better. We recommend 20 MB/s or higher, and perhaps a lot higher.
So the current version of the Model 3 manual has this to say about the requirements:
Correlation does not imply causation.There has been a notable surge of this issue with the V10 SW update
My statement can from the number of people who reported not having issues before V10 and having them after upgrading. Yes, people had issues before V10, but this iteration seems to have been exacerbated this round.Correlation does not imply causation.
I could say "There has been a notable surge of this issue as the weather has gotten colder" (much like the pattern with posts/threads about range and regen issues).
Do we have any data from V10 in July? I believe not.
Hey, just wondering how you have your Fit Plus configured. Are you using it strictly for TeslaCam or do you have a music partition as well?For example my Samsung 128GB FIT Plus drive- which I've been using for over a year now without ever getting the "slow" message- but another user with the same drive has. (from the benchmark they posted it sounded like theirs was defective though)
Yeah, I mean, why bring facts into a discussion right? Some nerve I've got!
Same deal for the other guy- while I've presented sources and data and real world examples, anytime I asked him to cite any he just shrugged and said he wasn't interested in discussing further.
Wonder why.
Checked on this thread again and see that we still have the vocal minority not wanting to ingest well explained information.
https://images.anandtech.com/graphs/graph14601/destroyer-latency.png
https://images.anandtech.com/graphs/graph14601/destroyer-99-latency.png
Original source and context at The Kingston KC2000 SSD Review: Bringing BiCS4 To Retail
Similarly, IOPs are very inconsistent on flash media. This is a somewhat exaggerated example (QD32) on an older drive (4 years old) but since they don't do this test on modern drives it will make do. This drive may actually perform quite similar to current USB3 drives.
Takes 4 minutes to go from ~15000 to ~500 IOPS
https://images.anandtech.com/doci/9756/bx200_480_pc1_575px.png
I leave 20% drive capacity unpartitioned, do not use same drive for music (adding read to the write operations) and park in the shade.
There was a request for a "citation" by one of the vocal members on how inconsistent flash storage is (latency wise in that case). Please note, the controller on even the lowest SSD is very likely superior to what you find in an average USB stick. Links below are for a 1TB sized recent SSD drive (KC2000) that is more than twice as fast overall as a SATA and entry-level NVMe drive so not with a bottom of the barrel controller. Further almost any flash drive that is mostly full or has been in use for a while has less headroom for housekeeping, or when it is reaching its thermal headroom, those high latency scenarios will be more frequent.
Will not go into explaining difference between average and 99th percentile, will just leave the numbers to speak for themselves. Suffice to say, one in 100 operations takes ~30 times longer than average. Instead of microseconds (359 us), the metric goes into milliseconds (10.5 ms).
Both drives have the same sustained rate, but one has a worst-case latency of zero, while the other has a worst case latency of 5 seconds. So, same sustained write speed, but very different latencies. Real drives of course are somewhere between these extremes, and typically the SSD drives have the lowest worst-case latencies, the cheaper USB flash drives the highest.
Because, to be bunt, the "other guy" has better things to do than listen to your blathering nonsense.
So let's deal with some facts, shall we?
Last night I sat down and wrote a simple test fixture, and ran it under reasonably controlled conditions .. not rigorous enough to eliminate all possible variables, but good enough for a "quick and dirty". I grabbed a couple of cheap flash drives (one Sandisk, one off-brand Kinstone) and measured their sustained write speeds after pre-conditioning them. The Sandisk measured about 30MB/sec, the Kinstone about 10-12MB/sec. YOU would argue that both drives should work fine, whereas *I* would argue that the Kinstone is unfit for purpose, as per my point about peak compression bitrate, buffer overflow, and latencies.
Watch out buddy Knightshade will be after you with his facts soon (I personally agree with ur recommendation).In my experience, a Blackvue or Thinkware 1080P unit will destroy a new non-endurance microSD card in a week or two. I have had Samsung, Sandisk and Transcend endurance microSD cards last well over a year in these units. While TeslaCam is arguably less demanding in one way (lower resolution video), it is more demanding in other ways (4 feeds vs 2 and a backend system not optimised to be a dashcam).
Since pretty much all cards/sticks are "fast enough", it is evident that it is something other than rated speed that causes the duty cycle problems, namely, the inability to handle continuous read/write plus housekeeping operations in non-ideal environments. It may also be that Tesla allows easy removal of a drive without properly unmounting it.
I've seen very few, if any, people using microSD cards rated for continuous video operation having TeslaCam errors or mangled/distorted or zero byte file video complaints.
SSD's certainly seem an option for some Model 3 users, but may not be the best choice for Model S, as the USB ports cannot supply enough power for many drives (I had to use a power/data split cable pulling power from the 12V outlet to get reliable operation for an SSD drive with only music on it in my S).
For the small price difference between an endurance rated microSD card and adapter and a non-rated card/stick, I do not understand the reluctance to buying a card rated for the purpose or the insistence that "any" moderately fast USB card/drive will work reliably in a continous duty cycle.
Any Tesla "bug" would surface for all users, not just a hapless few. There may well be issues with how Tesla has built TeslaCam, but the only variable right now across users is the storage medium as we all have the same hardware and software.
I used the same 128GB Samsung Fit Plus drive for months without issues but I've got a music partition on mine as well as the TeslaCam partition and I listen to music constantly off the drive. Maybe the fourth camera along with music playback pushed it over the edge because the too slow messages started showing regularly after the v10 update.One 128GB FAT32 partition, used for dashcam/sentry only. I have a separate 256GB Samsung BAR drive for music (as I've got a couple hundred gigs of lossless music stored).
The camera drive is in its own port- the music drive is in a USB hub along with 2 phone charging cables going to the factory phone dock plugs.
