I agree with that, that looks well in spec for most manufacturers, and the only fix is shimming (which may not be a factory approved fix, although a body shop might do it anyways).Yeah, that's not so much a panel gap issue as it is a flushness issue. Like the bumper looks like it's sticking above the plane by 2mm. Unfortunately, as many have noted in this thread (and other panel gap threads on TMC), 2mm is within Tesla's spec.
It's not that this cut-line issue cannot be fixed; it's just that fixing it requires someone to remove the fascia and re-shim it. And that will cost money + time. It'll be unlikely Tesla pays for that.
You may want to just stop looking at that part of your car. Luckily for you it can't be seen when you're driving...
That's surprisingly poor for a Toyota although they aren't as meticulous building cars as they used to be.
Lol that's part of the charm for Tacos, FJ Cruisers, Jeep Wranglers. That gap you posted are definitely to spec hah.
I think Tesla's fit and finish are getting pretty good. Great to see their improvements over time, and they're addressing most issues as they're discovered.
That’s hilarious - you obviously forgot your calipers on delivery day and probably also forgot to post the whole thing online.
After reading this thread yesterday I rode in a friend‘s 2022 Ford Explorer (a pretty high spec- not a cheap car). Noticed the entire dash assembly is not centered in the car. On the drivers side the end of the dash has a minimal hairline space separating it from the door panel when the door is closed, on the passenger side there is a 20mm gap between end of dash and door. I pointed it out and she just thought I was crazy to even notice or care about a detail like that![]()
I hope some of you folks don't use criteria like this for picking a spouse or partner. When you get bogged down in minutia, you often fail to see the overall quality of just about everything. I can go to the Sistine Chapel and pick out errors in Michelangelo's paintings, it doesn't mean I should.
It's your car to buy or not, I am not telling anyone what to do. I just think some of you may be missing out on enjoying a great car just because your fender is a MM to close to the door.
By that criteria if I'm paying $75k CDN for a spouse or partner you can damn well bet I'm going to ensure they are up to the standards I deem of a $75k spouse. If you have lower values that's fine but it's generally not okay to tell people they should just accept substandard quality when they are paying their own hard earned money on a product. There's pretty clear evidence that some shoddy vehicles come out of the Tesla facilities. Lots are great I'm sure but some aren't and that's the reality of buying a Tesla today.I hope some of you folks don't use criteria like this for picking a spouse or partner. When you get bogged down in minutia, you often fail to see the overall quality of just about everything. I can go to the Sistine Chapel and pick out errors in Michelangelo's paintings, it doesn't mean I should.
OP how does it look to your eye?
Not the ones built in America. The Lexus Made-in-Japan is another story altogetherThat's surprisingly poor for a Toyota although they aren't as meticulous building cars as they used to be.
Buy what’s acceptable to you. Keep in mind nothing is perfect. Not a Honda nor a Toyota, let alone a Hyundai or Kia. It is just that you fail to notice the issues. Even in a Lexus or a Mercedes. BMW is expected to have issues otherwise it is not a genuine BMW.By that criteria if I'm paying $75k CDN for a spouse or partner you can damn well bet I'm going to ensure they are up to the standards I deem of a $75k spouse. If you have lower values that's fine but it's generally not okay to tell people they should just accept substandard quality when they are paying their own hard earned money on a product. There's pretty clear evidence that some shoddy vehicles come out of the Tesla facilities. Lots are great I'm sure but some aren't and that's the reality of buying a Tesla today.
If it functions, it is within spec. If the gap is causing any issues such as wind noises or water leaks, etc then they would fix it.So does anyone actually know what, according to Tesla, their "spec" is for various cars / panels?
The only thing that I find infuriating is when I pointed out a very uneven gap and unflushness, tesla saying "it's within spec", and when I ask "what is your spec", them responding with "we can't tell you that". If they want to hide behind the spec, they must reveal the spec, and even if I disagree with their tolerances, at least I can agree the gaps are or aren't compliant with their own claimed standards for the $90k car.
I don't take calipers to delivery but I will quickly check mine at home, using my inside/outside/depth caliper I have from woodworking:
Then, if there's something egregious (like 5mm difference between left/right or flushness), I'll ask Tesla to correct it because I would be afraid of wind noises.
Neither flushness, evenness, nor symmetry (differences between left and right) are "spec" problems. Most specs are not tasked with making sure OCD is addressed, just that all the panels (especially the moving ones) do not rub against each other even with thermal expansion and vibrations.So does anyone actually know what, according to Tesla, their "spec" is for various cars / panels?
