Not “arcane”, which means known or understood only by a few, since many billions of humans use the metric system on a daily basis. But somewhat “archaic”.NASA still using feet and miles. Just quite arcane and silly.
Unless institutions like NASA start to completely ditch using these units, there is no hope to change public's mind.
For everyday usage (non scientific, non engineering), imperial is a better system.NASA still using feet and miles. Just quite arcane and silly.
2, 4 and 5,280. The volume measurements aren’t hard to remember. And I already said length measures are better in metric. You didn’t address my points at all.How many pints is a quart? how many quarts is a gallon..? how many feet is a mile? enough said..
Entire world gets by perfectly fine with metric.
As a Brit I have in my lifetime gone through the decimalization of our currency, the move to metric units for foodstuffs etc and of course the use of C instead of F. I have no problems setting my thermostat. I also lived in 2 European countries where distances and speeds were also metric.For everyday usage (non scientific, non engineering), imperial is a better system.
Have you ever used a Celsius thermostat? You set the temperature using 0.5 degree increments. How is that better?
How about buying meats? A pound of ground beef is a useful standard measure for cooks. A kilogram is too big a unit for most things. Likewise for weighing yourself. For pounds, decimals really aren’t needed, kilos, they are. And ounces are again a useful measure, grams are way too small.
How about volumes? I buy pint, quart and gallon baggies at the store. In Canada, they are marketed as small, medium and large with no size consistency between different manufacturers.
Length measures are about the only thing better in metric than imperial.
Of course you can get used to either system. I grew up in Canada, started off as imperial, went to metric, and now I’m in the US in imperial again. I notice though that one one wants to actually address my three examples of where imperial is better than metric. I’ll take that as a win.As a Brit I have in my lifetime gone through the decimalization of our currency, the move to metric units for foodstuffs etc and of course the use of C instead of F. I have no problems setting my thermostat. I also lived in 2 European countries where distances and speeds were also metric.
Now for the important things in life. Trying to remember from the last conference I was at in the US - what size are your wine bottles?
Some reasonable comments about ease of use, although metric is just as easy one you get used to it.For everyday usage (non scientific, non engineering), imperial is a better system.
Well @Cosmacelf , I usually find myself agreeing with you... gotta go the other direction this time.For everyday usage (non scientific, non engineering), imperial is a better system.
I did say that length measures are better in metric … mostly, as you point out, because we use the 1/10 measure, centimeter.Well @Cosmacelf , I usually find myself agreeing with you... gotta go the other direction this time.
There are plenty of imperial "fractional units" that are commonly used, as they are applicable to everyday life:
I think your point about "everyday usage" boils down to useful unit granularity. And typically the granularity required is what's generally useful (in this case in "everyday usage").
- a quarter or half an inch to the left
- 1/4 mile walk to the store. Or a drag race
- half a gallon of milk
- 1/2 a cup of water
- 1/4 pound burger
- 1/2 a yard farther
- etc...
It's easier to use whole numbers that are at most 2-3 digits long. It's much easier to say "20 gallons" than "2560 ounces". Likewise, it's easier to say "32 centimeters" than "0.32 meters". It's also not terribly easy to detect/accurately measure below say
The beauty of the metric system is that if the unit size is the wrong granularity (large or small), you can shift a decimal point and have the order of magnitude that fits your use case... if you want. The reality is that humans are typically lazy, and default to using a few common units. So most folks probably say "300 meters" rather than "3 dekameters" in same way that "16 oz." is what you see on beer cans rather than "2 cups".
One example you gave where the laziness is manifest is temps... 1 degree C is course enough that a full unit either way may be too much for comfort. And saying 38.5 is clumsy. But nobody uses centidegrees... because... well "humans".
But I would say there's absolutely no reason "3/8" of an inch or "2.5 gallons" is inherently better than "1-1/2 centimeters" or "6.5 liters" ... it's all really about what you are used to... and that's often units that you can often use whole numbers with. And metric's gotcha there.
The other "everyday use" factor you didn't mention is conversion. People do that every day... ai bet you can find a "tablespoon/ounces/cups" conversion chart it every kitchen. With metric that's so much easier...
The biggest hurdle is what you are used to... those aforementioned lazy humans don't like change...
I guess my point is "better" is rather subjective. For what? Using whole numbers? Ease of conversion? Granularity? Number of digits to write?I did say that length measures are better in metric … mostly, as you point out, because we use the 1/10 measure, centimeter.
But we don’t use centiliter, thus making volume measurements silly (242 ml baggies), and centigrams, making Kilos too big a measure requiring decimals in ordinary usage. And what do you do with Celsius degrees where a single degree is also too big a measure for ordinary usage again requiring decimals?
I find it interesting that everyone is so invested in the “obviously better” metric system (and it is obviously better for science and engineering) without pausing to ask whether it is actually better for everyday use. My three examples (weight, volume and temperature) show it is not better and no one here has said otherwise.
US is just being arrogant. The world isn't going to ditch metrics and adopt imperial, and so it is only a matter of time US will have to adapt.The US is obviously an outlier.
Translation: I'm used to imperial so it's better. Don't mistake familiarity with quality.For everyday usage (non scientific, non engineering), imperial is a better system.
Today I asked my spouse — who does not cook — how many teaspoons in a tablespoon. She didn’t know. Neither did I. Answer: 3. My response: huh? There are 4 pints in a quart. Why aren’t there 4 tsp in 1 tbsp? I have no idea. It’s nuts. And then there are “fluid ounces” and (not) fluid ounces. Again: hun? The imperial system is based on a grab bag of random unrelated stuff from centuries ago. I really dislike it.How many tablespoons in a cup?
My high school physics teacher vs. a student who tried to argue that nothing was wrong with imperial:2, 4 and 5,280. The volume measurements aren’t hard to remember. And I already said length measures are better in metric. You didn’t address my points at all.
Of all the things to draw a line in the sand for...For everyday usage (non scientific, non engineering), imperial is a better system.
Hogsheads, what else?Trying to remember from the last conference I was at in the US - what size are your wine bottles?
