Hello everyone.I'm waiting for my model 3 it still says Sept.-Nov. but i want to have my charging options already set up.So I have a detached garage with 2 110v outlets.there is also a switch which turns power off to those outlets.My question is will that be enough for my daily commute?I only drive 14 miles round try for work.the breaker that goes to the garage is 20A.Should I change one of the outlets to 15-20?
Do you also have lights in the garage? Are they off that same circuit or a different one? Are there any other electrical devices in the garage whatsoever?
Is that circuit that goes to the garage *only* for the garage?
So that switch may likely be a mandated "disconnect" when running power to a different building. I have seen this before. You might want to check to make sure the switch is 20a rated.
I nearly always will recommend something more than a 120v circuit for home charging. I can't comment on the cold weather charging situation as others have, but I don't disagree with what has been said here. Your range needs do sound very limited though.
I absolutely would upgrade one of those receptacles to 5-20 as long as the circuit breaker is 20a and the wire is 12 gauge (or larger). You want the least number of connections in the circuit for EV charging, so if you can, it would be good to plug the car into the first receptacle in the chain in the garage (but this all depends on the layout). From a NEC standpoint for EV charging circuits you are only allowed to have a single receptacle (not even a duplex receptacle), but since this is not like a new circuit specifically for EV charging I doubt it breaks any rules. You will need the Tesla 5-20 adapter naturally as well (this give you a pretty big speed boost in charging over the 5-15).
Is the wire in conduit to the garage? If you were lucky, you might be able to re-use a conduit relatively inexpensively to upgrade to a 240v circuit of some kind (maybe do a sub-panel). Feel free to post pictures of everything (including your main panel with the cover on and off and the sticker on the door) and we can look at it for you.
If there is a switch, first, make sure that both outlets in each socket are switched, not just one. If the switch controls all of the outlets. I'd recommend having the switch removed, not only to make sure that the plugs are on, but to better handle the current.
Might as well put baby proofers in the other outlet so that you aren't tempted to use it as well. I vacuum turned on while charging will probably trip the breaker.
As noted above, the switch may be a code requirement just FYI. As long as it is rated for 20a it should be OK.
I'm currently charging at 120V in my garage as well. My commute is about 20 miles and this works just fine with overnight charging (but I live in CA with always mild temperatures). I usually charge up to 70%, so I always have a little over 200 miles available in case I need to make a longer trip (and there are also plenty of superchargers in the area if need be).
One thing I'd recommend to do is to check the outlets, especially if they are older. When I first started charging I noticed that the plug and outlet got warm and the voltage dropped a bit, presumably since the contacts in the outlet were worn out or oxidized. I installed a new receptacle and now the plug stays cool.
Well done. Having a new receptacle for an EV charger is a great idea. Cheap insurance!!!
Soo... apparently there's no true battery heater in the model 3. It sounds like they use waste heat from the motor/inverter even when the car is parked to heat the battery. I can't imagine they actually feed 6kw into the inverter and its stationary motor and don't cause something to burn.
So when you run electricity through the coils in an electric motor as it is operating the wire heats up. The same thing happens with an electric resistive heater. Someone at Tesla realized that they could just run wire through the motor but I think without running power through the opposing coils and so it causes heat to build up without actually creating any torque. Thus using the motor as a resistive heater. It seems like maybe a bad idea, though let's assume it is 6kW worth of heating. I suspect that when actually driving the motor is using a lot more than 6kW, so perhaps it is not an issue? (the cooling system does run when they do this - it uses the coolant to move the heat to the battery)
