SSedan
With all the stressing I am shocked nobody considered that maybe it is new parts seating a little. You are supposed to double check wheel torque 50-100miles after having the wheels off as a general rule on all cars.
I would be interested to hear if retorquing lugnuts is a standard pre-delivery practice across the industry. Seems like it should be given that we are told to check them any time after the wheels are off and the first assembly would be the time things would be most likely to loosen before everything get all mated together and seated.
In practical terms I think this could be as simple as an anticorrosive film that is thick and time under pressure it is migrating out from between the rim and hub.
Torque is about finding a little elasticity in the assembly be it stretch or compression of something that stops vibration and temp swings from loosening the fastener. Too low a setting can be dangerous if the fastener begins to vibrate loose.
If the lugnut stays on and doesn't loosen further at 80lbs it is not a safety hazard, when it loosens and allows play that is a safety hazard.
I am NOT saying only go to 80, use the factory spec, but if all were at 80 and none loosened more I am going to say don't sweat the small stuff.
