There you go, I would bring it up to Tesla but I would not let it affect enjoying your car. CongratsThe gaps between the same panels on opposite sides are not the same. The driver’s side gap is noticeably wider.
I ordered the same one. Looks greatFinally graduating! No issues or panel gaps. View attachment 779674
It was part of the refresh/introduction of flagship Model S/X stuff into Model Y/3 - like how Ryzen and the 12V Li-ion battery were first seen in China on the Model Y, the rear dual pane windows were expected but haven't been seen in North America yet.Should M3LR has double-glass rear door by default?
Word of advice: if you have any sort of issues upon delivery with things you want fixed/adjusted, make that service appointment FIRST.
The app does not let you make more than one service request at a time. I made the request for my Homelink installation, thinking that appointment would be quicker, and because I wanted to be able to get into my house.
Then I wanted to make a second appointment to resolve all of the things I wanted to be looked at, and realized that there was no way to do that, except to cancel the first appointment.
They can do the Homelink installation as a remote service call, but not paint or dents. Not sure about panel gaps, but I'd guess all of the bodywork stuff has to be done at the service center.
Anywho, I was able to work it out with someone via messages in the app, and they made a second appointment for the other items and had me send the pictures and list via e-mail.
The list I sent:
1. Inside the front door hinge areas, there is no paint on much of the surfaces, and different layer(s) missing from one side or the other. The driver’s side is mostly white with blue overspray, and the passenger side is mostly yellow with blue overspray. I don’t know how many layers are missing on either side, but my other vehicles have always been painted and had unpolished clear coat in this location.
2. The panel gaps between the A-pillar, front quarter panel and front doors are visibly much wider on the driver’s side than the passenger side. Primed, but unpainted surfaces are visible on both sides in the gap, particularly on the driver’s side. The driver's side front quarter panel is not flush with the door. The door is further in. It's hard to see, but easy to feel.
3. The passenger side quarter panel has a misalignment with the panel below at the headlight. This is probably related to the passenger side of #2 above.
4. When the frunk/hood is fully open, the rear edge pushes on the passenger side windshield wiper. I’m guessing that there is an adjustment that can be made so that it doesn’t open that far.
The remaining items are comparatively minor:
5. There are light scratches at the rear bumper and low on the rear passenger quarter panel. They will probably buff out. I couldn't even get a picture of the quarter panel one because it disappears in the reflection of the pavement.
6. On both sides, the rear quarter panels don’t align with the trim at the intersection with the rear window / roof glass. Maybe they aren’t supposed to, but it doesn’t look right.
So... I think I've reached the graduation point from this thread.
May your delivery dates arrive as soon as possible, and take it real easy on that accelerator pedal.
0-60 might take 4.2 seconds, but 0-35 is a lot closer to 1![]()
You're lucky! You got an update and it's a good update at that!Have the same order… M3 LR Blue exterior, White Interior, Aero, and No FSD.
From Delaware but being delivered to NJ showroom since they can’t sell in DE.
Ordered 03/02
Original EDD 05/29-06/26
Updated 03/08 EDD 05/15-06/12
Ordered 03/02
The bright white inside the driver's side door hinge area is really quite noticeable. Like, I saw it immediately upon opening the door for the very first time to get in, before I even took out the checklist or started looking for flaws. At least the yellowish color in the passenger side is a lot less vibrant.I would have never noticed any of that...thank God.
What spec? I have very similar order details and location.
With demand the way it is, they aren’t likely to fix this stuff before it leaves the factory any time soon. If it’s fixable at a service center, they could easily tighten QA but that would slow down delivery and we’d all be on here doing this anyway.The bright white inside the driver's side door hinge area is really quite noticeable. Like, I saw it immediately upon opening the door for the very first time to get in, before I even took out the checklist or started looking for flaws. At least the yellowish color in the passenger side is a lot less vibrant.
The gap between the A-pillar and the quarter panel is wide enough on the driver's side that primed, but unpainted metal is very visible in the opening. That is also yellowish, which really stands out between the dark blue.
If those two items weren't there, I probably would have looked at the rest of the car a LOT less closely than I did. The more I found, the more closely I looked. If you'll notice, a lot of them are cases where the driver's side and passenger side don't match. If both door hinge areas were white, or both were yellow, I would have assumed it was the way it was supposed to be. (But would be VERY disappointing in a car at this price.) Same thing with the A-pillar gap. If they were both wide enough to see the frame underneath, I might have thought it was the way it was supposed to be. When the two sides are visibly different, it makes it obvious that one of them is wrong.
All of the panel gaps on the Infiniti I traded in were so tight that not enough light got in to see, and so they just looked like thick black lines. On my Tesla, most of them look that way, but not the ones at the driver's side A-pillar area.
Yep, I did cash payment. And everything is completed. I've called and talked to several people. They all say my account is good to go.I am in mn too. My original order showed up in a little over a month. Something is not right with your account. Did you setup cash for payment originally and are all tasks completed?
Model 3 LR : Aero : Red: Black Int : OD 2-27-22 : EDD May 6-June 3
I have no idea what I’m doing as I’m new to Forums in general so please bear with me. I’ve read all the posts in this forum dated since 2-27-22 so I’m caught up with current events. I called Tesla and spoke to a salesman who said my order is fine, just waiting for a VIN and EDD. No trade in, financed with Tesla, home delivery in Orlando area. Tesla’s are everywhere here and finally got to drive one the other day. As stated in the title, so much to learn. I appreciate all the info/advice posted here and hope my time in this forum is short.
Your SA seems misinformed. The Fremont factory is the only US factory currently producing model 3s. They’ve JUST started producing model Ys out of giga Texas and that’s all they’re focusing on right now. EDDs are super skewed with end of quarter push. I anticipate a lot of EDD changes within the last ten days of the month as Tesla tries to deliver as many possible units to show the investors on their end of quarter resultsDid your SA tell you where the car would be manufactured? I am in Oregon and my SA told me that it would be built in Fremont factory. He mentioned that the East coast cars are made in Texas plant. being in MN, I would think Fremont, but if it is the Dallas facility, maybe that would be a factor? Either way, that is really discouraging.
I just changed my Sunday delivery for pick up tomorrow. I had it depends on how much parking your local dealer has. They want to deliver as many cars to homes so parking at their lots isn’t impacted. Apparently in Buena Park they’ve been Uber customers to their cars is what the SA said. I can’t confirm that. But Can tomorrowThey changed my delivery to home delivery. I wanted to pick up. Do you guys think that can be changed back?
Also anybody can provide the 800 number to contact them. The SA ghost on me and no answer at the text I sent to switch payment method
Thanks
My OD was early Feb (2/5), I received my Vin last week (3/7). Delivery scheduled for 3/19. Things can move fast.I'd love this lol... but not getting hopes up since I was a late Feb OD (2/26) and my one and only EDD has been 5/13-6/10 and hasn't changed since. *fingers crossed* I get it sooner!
My OD is 2/11 as well. My EDD is still 5/3 -5/31. Im in Dayton, OHDang! Sorry to hear that.. I have same order also pickup in Philly. My OD is well after you @ 2/11 and my ODD just got moved on Tuesday from May-June to 3/22-3/31. One would assume I should get an April bump too… I’ll post if/when it does.
