Of course it does, it's the default setting. The Bolt's stronger regen setting is more aggressive than the Model 3 RWD, physics kinda dictates because of rear wheels versus front wheels doing the breaking. This was the case in the older Model S original RWDs, too.
It doesn't have a wheel regen brake paddle that the Bolt has, which is a touch I like as I use it for canceling CC fairly often, because the Bolt doesn't have an option for TACC. It, if you use it (my wife doesn't), makes it easier to get close to pure 1 pedal.
Tesla (across all models) curiously does feather off the regen at very slow speeds (below 5mph) unlike the Bolt, so you'll end up touching the brake pedal more often if not using Autopilot. Especially if you have Creep setting on (approximates Automatic transmission creep). It doesn't fight to keep you stopped once you are stopped, like the Bolt does in "L". They also don't have any regen on the brake pedal, to avoid the soggy brake feeling so common in hybrids/EVs. This is overall approach is relatively unique as far as I know, I'm curious about how these new vehicles will handles brakes.
