Model S P85D lower and lower range for 3 - years - WARRANTY ENDING SOON - what to do?
My 2015 P85D has a working battery, but the range sucks. I typically get about 120 miles from full ("230 miles") before I am at 15% battery. Even when my grandpa who is almost 80 drives it, he gets about 130 miles max.
We can basically only go 50-60 miles one way before we have to turn around and head home to charge for 9 hours. SO FRUSTRATING! I feel like it's a Nissan leaf.
We have reported this to Tesla many times over the past 3 years, they keep saying the battery pack is fine! Every time they just say they diagnosed the stats remotely and it's fine. Local service center is just as useless and unhelpful - they don't even really look into it at all, they just say it's fine every time and try to dismiss my issue, and tell me to drive slower. I mean, grandpa doesn't drive fast (even though it's the Performance version we paid extra for).
The supercharger also takes longer than it used to - about 1 h 30 minutes on my car to fill up to 90%, 2 h if I leave it plugged in to 100%, it actually never reaches 100% it stays at 97-98% and just stays there for ages. I only fill to 85% typically to preserve the battery pack.
MY QUESTION IS THIS:
Is the battery deteriorating? And as the car is still under warranty for a few more months, can I do ANYTHING while it's under warranty to get Tesla to cover a battery fix and/or upgrade, in order to use my warranty while I still have it?
I'm worried that when the warranty ends soon, it will die, and I'll have to pay $25,000 or so, and may not even have better range than now.
A friend I know went into Tesla with a battery range issue on his p85d, not only did they tell him the battery died while it was there and gave him an entirely new pack for FREE, but they even upgraded it to a P90d and did the software update that updated the graphics on the screen as well. Any way to get that to happen?
Or if nothing at all gets done under warranty (the most likely outcome given tesla customer care and assistance to date), should I send it to an aftermarket shop for a fix or upgrade after the warranty ends? Could an aftermarket shop even do anything to help my range?
Have others shorted the battery or done anything to get a tesla replacement under warranty? Not going to do anything unethical, but just curious what has happened if the battery suddenly dies - wondering if they will actually honor the warranty?
It's INCREDIBLY frustrating to have been reporting this for 3+ years, and have double the supercharger time to get to 85%. I feel like I spend one minute sitting at a supercharger for every 2 minutes of driving. It makes the car feel like a burden, rather than like a real functional car that makes transportation easier.
Reactions: Maaz
ucmndd
9,085
17,631
The slow supercharging is “by design” and affects basically all 85kwh batteries. Tesla will do nothing to fix this as they’re the ones that caused it.
Your car reports 230 range miles available at 100% which is pretty normal for your vintage car.
What wh/mi does the car report on these trips where you go 120 miles but use 230 miles of range? Is this all in a single long drive or are you getting 120 miles from a full battery over multiple days/trips?
As I said in response to your other posts, Tesla isn’t gonna give you a new battery based on what you report. There’s little/nothing you can do to change that.
Reactions: Rocky_H
Following as I am in a similar predicament with a upcoming warranty expiration on my late 2014 P85+ where full charge says 245, but I can only get 180 with 2% left with light driving. Any heavy driving and I’m down to 120. I have not taken it to the service center for it yet, but would appreciate any insight as to how to get them to look at or acknowledge my issue.
gaswalla
Model S,3,X.. CT with Austin delivery
Sep 23, 2012
3,873
4,780
San Diego
The following is from personal experience:
Get TMSpy or ScanMyTesla app and the appropriate dongles and cables - this requires a bit of research, (about 15 minutes), and hopefully you are motivated.
Run one of these scanning apps and get the data on your battery... you will be able to clearly see the amount of degradation and other issues
In my case, I had a similar experience to yours and I assumed I was a part of "batterygate" (google it too if you need to)... what I found was that I had one module that wasn't functioning correctly. I took that data to Tesla, they interrogated the battery properly (knowing that I had info already), and they concluded that the car needed a new battery.
Don't just assume you have normal degradation or are a part of the latest Tesla scandal (batterygate, chargegate, etc...).. Go get the data and at worse, you can track the data over time
I am looking at doing this? What did you see when you did it? Cell imbalance? Just curious as my Telsa seems to be losing 1 mile of range per 1000 miles recently. Going to try a full cell rebalance soon. Additionally, it is dropping 3% of charge within an hour of a 90% charge, so going from 90-87% right after charging.
Doanster1
1,227
662
Oregon
Your last issue is well known ever since they lowered the threshold for when the battery coolant heater kicks in and stays on. Sweet spot for most of us P85D owners seems to be 75%-80%. 90% is guaranteed to have the coolant heater run for a while, hence the quick drop of 3%.
Reactions: Rocky_H
My own 2c.
I was in same boat. Tesla SC told me to do several discharge/recharge cycles. On the first one, I depleted the battery to zero and charged it slowly for 24 hours. After 1st cycle, I lost 40 miles of range and got the battery charge level reduced alert. SC then advised a new battery was needed.
Reactions: Russell
