2
22522
Guest
Yes, that is true if the hinge is long enough to include also the latch.When I see that I think it was hand built, and hope the release versions will be better. I highly doubt there will be any stress on the sheet metal - all of the stress should be on the hinge.
If the sheet metal between the hinge and the latch is bending, then the unloaded part of the sheet metal surface that extends past the latch toward the C-Pillar will end up high.
I just can't see that seam leaving the factory as far off as it is.
