Garlan Garner
Banned
Digging the confidence here. Marked.
Absolutely love the Apple 5.14. <-------------I know teenagers......you don't know what I'm talking about. LOL
If and I say IF the Model 3 had the same identical battery pack of the Model S then I would say ....... yes.....you are correct: Problem - it doesn't. The battery pack is smaller and there are fewer cells. Soo with that said.....I don't believe 0-60 is going to go sub 3.
The current track record for the Model 3 0-60 time is 4.6, I pray that I'm totally wrong because that's the car I'm waiting for, however I can't see Performance knocking off 1.5 seconds.
I don't agree with your premise as the Model S is compared to what?
Are you saying that Tesla/Elon cares about the 0-60 times of another car.......so he limits the 0-60 time of Tesla to match? Have you heard of the Model S P100D?
Losing 1000 lbs is eeual to about gaining 100hp in drag racing.
Also the cells in the model 3 are more advance.
Sure the cells are more advanced, however the power levels stated are the power levels stated a 75Kwh battery is a 75Kwh battery...no matter if its the Model S version or the Model 3 version.
All that means is that the Model 3 is using fewer cells than the Model S to equal the same amount of power. Now....the motors. Are the motors in the model 3 the same as the model S.....or are they smaller?
Yeah track time of 4.66 for a car with advertised 5.1 sec. How much different are P/D versions of the 85kWh battery relative to the non-P/D versions of that car?
85 5.4 sec
85D 4.2 sec
P85D 3.2 sec (2.2 sec less than plain 85kWh version)
Shave 2.2 sec from 5.1 of Model 3 LR? 2.9 sec.... a best case scenario.
Again, anything in the low 3's and I'll be happy as pig in poop.
The ICE "smackdown" was for the next gen roadster. I have no problem with the Model 3 always being slightly slower than its Model S big sister.So some of you believe that a Tesla Model 3 with Ludicrous will only be slightly faster than a BMW M3?
What happened to the ICE smack down? There's zero physical reason that couldn't make it well under 3 seconds.
I'm hoping the AWD version is in BMW M3 territory and the Performance version is nearly P100D quick without the overheating issues due to the new motor design. Besides the first Model X versions which are no longer made, "Ludicrous" was always < 3 seconds.
I’d be pleasantly surprised if it were in the 2.6-2.9 range, but as indicated above 2.5 is probably the lower bound for now. P100D needs a raison d’etre at its price point.So some of you believe that a Tesla Model 3 with Ludicrous will only be slightly faster than a BMW M3?
