The battery pack level cost is under $14,000 according to the interview Elon have given in Germany (linked below, second video, 5min 50sec mark). My assumption is that cost equal to 30% to 35% of $40,000 price tag suggested by the reporter applies to 85kWh.
Verpasste Zukunft
Verpasste Zukunft
Hmm, reporter suggested 40k euro, not USD. And my understanding EM was referring to whole price of the car...
I don't thinik he says that. He says it is about 30-35% of the car's price. That's 21k even for the 60, and even with only 30%, isn't it?
http://www.teslamotors.com/about/pr...t-expand-supply-automotivegrade-battery-cells
"2 billion cells over the course of four years"
Press release clearly says Model S and X - no mention of Model E.
How many cars does this translate to? Thus, what growth rate can we expect?
Forbes, DB are putting it at 300K to 330K cars. But they are using current cell counts per car as it is. But aren't batteries supposed to get efficient every passing year?
Batteries are, but it's not clear that Tesla will switch, especially over the next couple of years. There is a massive amount of engineering in the. BMS, suspension, software, etc around the current cells. That investment is a major reason that Tesla choose not to develop the 40kWh variant. It's not just a matter of changing the cell count to make it work, and it's even more the case when you try to swap in cells with dramatically different properties.
Tesla certainly could do it, but we have no reason to assume they will. Especially once you consider the possibility that the per unit cost of the 3.4aH cells they are using might continue to fall, and result in a lower cost per kWh than the early production runs of the next gen cells.
I think the prudent assumption is that Tesla has locked in the basic pack format for now and we won't see a significant change until they come out with a GenIII pack with next gen cells. That will happen ~5 years into the production run for the S platform, which is a fairly typical run in the automotive industry before a major platform redesign.
If it's simply a larger capacity cell with similar chemistry and properties I don't see much of an issue in using it. Physical construction is unchanged and any voltage and current changes are an easy tweak in software.Batteries are, but it's not clear that Tesla will switch, especially over the next couple of years. There is a massive amount of engineering in the. BMS, suspension, software, etc around the current cells. That investment is a major reason that Tesla choose not to develop the 40kWh variant. It's not just a matter of changing the cell count to make it work, and it's even more the case when you try to swap in cells with dramatically different properties.
I'd think at this point any significant price reductions would almost have to come from density improvements.Tesla certainly could do it, but we have no reason to assume they will. Especially once you consider the possibility that the per unit cost of the 3.4aH cells they are using might continue to fall, and result in a lower cost per kWh than the early production runs of the next gen cells.
If Panasonic is able to get a 3.6ah yield at a similar price I can't imagine any reason why Tesla wouldn't start using it.I think the prudent assumption is that Tesla has locked in the basic pack format for now and we won't see a significant change until they come out with a GenIII pack with next gen cells.
Without a doubt, plus the fact that the smaller and lighter E won't need as many cells to get the same or better range than the S, and it has to be a cheaper vehicle.On the other hand, the Model E will be shorter and smaller, and thence the Model S/X pack may be too big/long?
Good to see you back here CapOp.
What do you think they will do about form factor for Model E? On the one hand, I agree with you that changing form factors is a big cost/investment/hassle (not least because the battery swapping station seems to be fit-for-purpose for that form factor?).
Tesla is already dealing with a change in cell count, voltage, and current, between the 60 and 85kWh packs. They just leave an empty space, or a sand bag or something, in part of the pack. It's hard for me to envision such a drastic chemistry change in the near term that would create parameters wider ranging than that. I'm also going with the assumption that near term future chemistry will be safer or at least as safe as current chemistry, it almost has to be or it won't be an advancement. I'm only talking about incremental improvements, not a drastic chemistry change.My concerns about the engineering have more to do with the physical cell count than the specific power density. If Panasonic offered up a 3.6aH cell with a similar per cell cost to the 3.4aH cells then I could see Tesla integrating them and pocketing a range increase. But a change that forces a reduction in the cell count would potentially be a substantially greater problem because it changes the physical structure of the battery and how it's wired together and built.
Tesla actually kept the same cell count, voltage, current per module, but used less modules for the 60kWh pack (thus resulting in an overall pack with lower voltage). So I think CapitalistOppressor is talking about an intra-module change in cell count being more difficult than just upping the capacity.Tesla is already dealing with a change in cell count, voltage, and current, between the 60 and 85kWh packs. They just leave an empty space, or a sand bag or something, in part of the pack. It's hard for me to envision such a drastic chemistry change in the near term that would create parameters wider ranging than that. I'm also going with the assumption that near term future chemistry will be safer or at least as safe as current chemistry, it almost has to be or it won't be an advancement. I'm only talking about incremental improvements, not a drastic chemistry change.
great chart- thanks Zzzz..
+1000
- - - Updated - - -
Whoa. Deepak shut Elon up when he was talking about being in Panasonic factories.
- - - Updated - - -
This needs to end so I can rewind that, lol.
