Once in a while I've hit both at once, but I can feel that I'm doing it. If I don't have time to reposition my foot I just treat it like I'm doing a heel-and-toe and tilt my foot to push on the brake.
Newer production (like the loaner I had last week, VIN 14k) HAS repositioned pedal(s). There is 0.5 inch approximately depth difference. Very good safety feature IMO.
I wonder if there will be a recall or service bulletin to retrofit older production. Seems like it would be a VERY good idea to offer that for owners that request it.
just tried this morning with my latest v4.5 (1.33.54 I think).
At higher speeds, getting the chime cuts the power.
At low speeds (0-5 mph or so), I can get at least 10 kW of power with the brake on.
I'm happy.
I swear that's not what happened when I tried a few weeks ago.
and with my latest version of v4.5,
now it's back to allowing large positive electric torque while the brakes are providing large negative friction torque.
I think this is very bad. I think the behavior from before is far more desirable.
Ahh, I think I see the difference:
accelerator then brake -> electric torque is cut. only brake is active.
brake then accelerator -> electric torque is live. 100 kW of battery power + 100 kW of friction brakes = no acceleration.
and with the position of the brakes, the latter is the one that happens when you're wearing wide shoes and you press the brake and accelerator at the same time. The brake is closer to you, so you hit that one first, and then as you press, you press the accelerator. When you press harder, you get more friction brake AND more electric acceleration.
Again, I think this is bad.
I was told that the issue was that I accidentally pushed on BOTH break and accelerator pedals at the same time, a common occurrence with men with large shoes, I'm only size 11, fairly average, but that evening I was wearing wide sole shoes. Be aware that both pedals are very close and this can happen to anyone, I'm much more aware of the position of my foot when pressing the break now.
The following part of the article rang true for me too. I really think the pedal placement creates what the author calls "design induced human error". I don't have 50 years of driving experience, but in the prior 20 years I never had a problem until my Model S. It's been a few months, but I hit both pedals again just this last week when backing out of my garage (steep slope, so I typically brake as I back down).This has caused problems to others too
http://www.greencarreports.com/news...la-model-s-is-pedal-placement-a-safety-hazard
The S is a gigantic car, I really don't understand why it has such cramped pedal placement.In 50 years and perhaps half a million miles of driving dozens of different cars, I had never inadvertently pressed both the brake and accelerator pedal. Not once.
Now, over one year and about 15,000 miles in the Model S, it had happened three or four times.
If we look at the sum of the vertical and lateral distances, the Model S has tighter overall pedal spacing than all of the 22 other cars except the BMW M3, a specialty high-performance model.
No thanks. I don't want abrupt braking when I graze the brake pedal.I have had the same thing happen to me, once, like you, where it was almost a big problem. Like you also, I have learned to be more specific about foot placement!
I really think this needs attention. They should let the brake pedal take full precedence. They know the event happens; why not just ignore the accelerator input when heavy pressure is on the brake?! Should be a firmware fix.
That's not remotely what Vger said. He said "heavy braking", not "graze". Further, he said to give the brake precendence, not to create a "abrupt" stop. If you grazed the brake, it'd then be a gentle braking (probably not too far akin from cruise control shutting off when you graze the brake).No thanks. I don't want abrupt braking when I graze the brake pedal.
Ironically, the Model S is already programmed to cut off power to the wheels in case of an inadvertent double-pedal situation--but it only does so part of the time. And unfortunately, it's the wrong part.
If you're driving along at 40 mph and happen to step on the brake pedal with your left foot--a highly unlikely situation--the power will indeed cut off.
But if the brake pedal is pressed first, followed by the gas pedal--the usual double-pedal scenario, and the one that happened to me before the near-accident--power to the wheels is not cut off.
The electric motor, which produces peak torque at low rpm, thus strains against the brakes, which greatly increases the stopping distance.
The software logic of the Tesla system seems to be "whatever pedal is pressed last gets the priority."
The human logic? I haven't a clue.
Agree, break pedal should have precedence when both are pushed.
