1.21 Gigawatt Hours?
Wow. You went all out on that one.It's the new battery that's coming out. It can encircle the Earth at the equator 161 times before it needs charging.
On your HPWC in the garage, it will fully charge in 8 years.
evGo can charge it for you at 30¢ per kWh, it will only cost $363,000 for a full charge.
Compared to the existing battery in the P100D, this new battery is the equivalent to a stack of the 100 kWh batteries that is approximately 1 mile high.
To charge this battery in the approximately 30 minute time period like a Tesla Supercharger, the only way you could do it is by using the entire output of the Arizona Palo Verde Nuclear Power Plant (3.875 GW). At 400V input, the charging current is approximately 3 million amps.
The supercharger cable required to carry this current is a solid cylinder of copper approximately 5 feet in diameter.
It seemed unbalanced with just gw and only certain people would get it anyway. Plus it's nearly 1000 times the awesome!1.21 Gigawatt Hours?
Old post but helpful. Helps eliminate some I might have considered.
Does TX DMV allow you to check on-line for the availability of a personalized plate combination? I found out many of the ones I had considered for my future Model 3 were already taken when I checked on the CA DMV site.Anyone in TX with WNDPWR? We are buying from Breeze energy which uses 100% REC supplied by Texas Wind Farms.
