Be sure you press and hold the button until the port turns white, then pull. If you're doing that and you're still getting orange or red, it's probably a bad connection between the handle and the car.
And a fun easter egg if you haven't found it on another thread: With the cable inserted and the car unlocked, press the handle button 10 times and see what happens...
Likewise. Arrived in 4 days, shipped from Newark, CA to my location in the SF Bay AreaGot mine in 2 weeks and it passed through customs to boot
I"ve noticed in one of the Canadian threads a couple of people who have obtained quotes from Tesla recommended electricians who have in turn seemed to suggest that "Tesla requires special wiring and procedures which drives up the price". Another one referred to a "Tesla specified installation". I'm not sure yet whether the prices were inordinately higher (my installation was part of a bigger job) though the owners in question are getting second estimates from non-recommended electricians so I guess we'll see. My understanding is that any electrician who install correctly according to code should be fine. The Tesla recommendation is (AFAIK) mostly so owners don't have to go searching for an electrician who knows something about these chargers.
Are there any special Tesla standards or procedures? Is it worth paying more money for an electrician who knows these procedures or are these recommended electricians taking advantage?
The only "special procedure" is a circuit, including wiring and breaker, that matches the setting you're going to use. (There are dip switches that can be set to accommodate various circuit sizes.) For the maximum charge rate that means 100 amps. There's nothing else special.Are there any special Tesla standards or procedures? Is it worth paying more money for an electrician who knows these procedures or are these recommended electricians taking advantage?
I got my new HPWC and noticed that the inside is different than the previous model. Just for my edification as I'll get electrician to install it, how does one connect L1 and L2 with the 2 screws in the middle?
Also, I noticed this new version doesn't have a ground on the unit.
I see it. It's the cube nut thing on the pcb.The ground is right there, in silver.
If the HPWC had been wired to your fuse box with a telephone cord, it would still likely show the correct voltage. The issue is what is the voltage while it's charging the car? You can't detect bad wiring/connectors by measuring the voltage without a load.
I love it when people throw around, "unacceptable "Unacceptable
Ordered my HPWC June 30th (24" cable, told backordered 3 weeks, paid for overnight). Will let you know when I get it!
I don't know how close you are to a Service Center but its worth pointing out that service centers tend to keep these in stock and it might be worth a call to see if they have one to short cut the 3 week delay!
