brkaus
Google. For example - How do I install an outdoor receptacle box on vinyl siding?I have a HPWC on the way. I plan to install it on the outside of my garage on vinyl siding. Any install ideas for vinyl siding?
Wondering if anyone can point me in the right direction before I call Tesla.
I had a wall connector installed about two weeks before I received my Model S last Friday.
At Tesla there were no issues using their wall connector. version 2
When I got home and plugged in I could not get a green flashing light.
It will start to connect and turn either amber or red. The wall connector will go from solid green to solid red.
If I keep disconnecting and reconnecting it will eventually connect and start flashing green.
What I noticed last night is when I inserted the connector and both the port and the charger turned red, I pushed the reset button on the side and it clicked, turned green and started to charge the car. This is repeatable. Pull it out, reconnect, turns red, press reset and turns green and starts recharging.
Is there something I can start looking at or should I just call Tesla?
Any insight would be helpful.
btw, It's a P100D and so far it's been great. No issues at all with the delivery. Only one small spec in the paint we could find which wasn't worth the hassle to get fixed. Even came with the wireless charger that wasn't available when I ordered it.
Congratulations on your Tesla! Did you try shutting off power to the wall connector and waiting 30 seconds, then powering it back on? If that doesn't help, you might want to have an electrician check all of the electrical connections in the unit. As a last resort, you can call Tesla.
At least you have a way to work around the issue. Does it keep charging until complete when you press the reset button?
I did the first night.
Interesting thing, last night I came home expecting the same issue and plugged it in and started charging, no issues.
I guess I'm just going to have to watch it.
Thanks for the reply!
Gen 2 installation manual says solid red on the WC is a "hardware failure".
See troubleshooting section - https://www.tesla.com/sites/default/files/downloads/wall_connector_installation_manual_80A_en_US.pdf
The internal connections/lugs expand and contract with heat from use, which tends to loosen the connections Once they are loose enough the power becomes slightly variable, and the car can sense this and trip a blinking red light. Have an electrician (or yourself if you're comfortable) take off the cover and check the torque. Just happened with me, loose wires, solved.After 4 years of trouble-free operation I had mine show red in the morning when I came out, but the car was fully charged (80% - my daily commute charge). Came home that night, plugged it in, no issues - turned green. Next morning same thing, connector and WC show red but the car is at 80%. Went like this for several days until one day it showed red the minute I plugged it in. Turned off the breaker to the WC, let it sit for a couple of minutes. After turning back on everything went back to normal. This was a couple of months ago and I haven't had any issues since then. Just another data point for you all...
If it is indeed a grounding issue lowering the power output won’t help. If your wall charger is on a 50A circuit, it should operate properly at 40A (80% of 50).My Gen 3 Wall Connector suddenly started having charging interruptions every hour or two while charging my 2016 Model S 90D. One red blinking light on the connector during the interruptions which points towards a grounding issue. I’ve had the car and wall connector(installed by an electrician) about 6 weeks with no issues. Did a trip last weekend and did some 110v charging in an RV park as well as some supercharges and that following night the problem started.
I just happened to have a Tesla Mobile Service tech out yesterday doing an unrelated repair and he said the problem is not with the car from what he could see. He did say that is should be charging at 32 amps instead of 40amps(50amp breaker) as its bad to charge above that. I found that odd as I’ve never heard that before. I bumped the charging amps down to 32 on the car’s screen but the interruption problem persists. Should my next step be to open up the wall connector and move the dial down to 32 amps from there?
Opening up and changing the dial will have no operational difference from setting the current lower on the car screen. If it doesn't function when set down from the screen, it won't work with the dial.I just happened to have a Tesla Mobile Service tech out yesterday doing an unrelated repair and he said the problem is not with the car from what he could see. He did say that is should be charging at 32 amps instead of 40amps(50amp breaker) as its bad to charge above that. I found that odd as I’ve never heard that before. I bumped the charging amps down to 32 on the car’s screen but the interruption problem persists. Should my next step be to open up the wall connector and move the dial down to 32 amps from there?
tl;dr if I have a dual charger car should I buy Gen 2 or Gen 3 wall charger?
