Thanks for always providing quality unbiased feedback! Most don't realize the weaknesses of carbon ceramics and just assume they are gospel due to the cost.At least don't buy xt910, 970 is better for street on Tesla's.
But I wouldn't buy RB rotors - bolts are expensive and disposable after track use. Also, slots on rotors make heavy grunt noise at braking. Calipers are too soft and bend way too much under pressure. And then customer service horrible by design. Reviewers who praise complete loss of any fade should let us know if they paid a full price for upgrade...
I'm quite certain that rotors are too small even with improved venting, so we need forced air, water cooling and largest possible rotors with proper AP/Brembo/ST calipers.
I use UP CCB now on m3p - it's much less dust, much better feel vs stock, but looking at my temperature on the track - this exact samr 400mm combination is not good enough for Plaid. Large track would put 3-4x heat energy in brakes on Plaid vs m3p.
It's also important to know - CCB have much lower heat capacity at the same size and much worse ventilation, so they get stupid hot and overheat calipers by radiation and boil fluid. It's not only about price - unless you have high pressure forced air, carbon brake are just worse than gray cast iron by all performance measures.
Their main benefit is weight reduction, and certainly heat dissipation and system overheating is a major challenge.
