Yep they work.Does the actuate_trunk work on Model S / Model X? Always get invalid_value when trying.
How are you sending the API request? More often than not your implementation is wrong.
Yep they work.
Thank you for replying
I use this: https://owner-api.teslamotors.com/api/1/vehicles/<vehicleid>/command/actuate_trunk?which_trunk=rear
All other commands work.
Instead of passing the commend as parameter on the url just pass them as value in the body. Note the additional Content-Type header and its value to indicate the type of data you are passing in the body for the POST request
I pulled the latest teslams.js from github and it's working now... Not sure why my npm update didn't update that package.
Tesla Control lets you schedule start and stop times. It’s done with background tasks.Does the API support changing the charging start time? I can't find it, but it seems like a pretty fundamental need. If the answer is "no", then are all the apps that support changing the start time just manually starting the charge at the new time from the app/server end? Sounds crazy to me!
I can find the start/stop charging commands (no details about what the httpbody payload should be though?)... however, is there such a command that could set the charging current remotely? I haven't seen one in the official app but I'm wondering if an API for it exists (or if someone managed to sniff one out)?
EXACTLY the reason why I asked for it tooUnfortunately not. This is a holy grail I have been waiting for (And tweeting Elon).
If the API allowed us to set the charge rate, I could utilise much more of my solar export by keeping the charge rate the same as solar excess.
Mate it doesn't existEXACTLY the reason why I asked for it tooTweet him again, I'd imagine we're not the only ones thinking about this... Since my solar inverter can't work in island mode, and I can't send any predetermined amount of power towards the car first before exporting excess, having the car "pull" a corresponding amperage out of the inverter in line with solar output seems to make a lot of sense!
I'm guessing you already tried obvious stuff like command/set_charge_current (as opposed to set_charge_limit) just to see if the API actually exists right? (i just tested it now, got a 400 bad request).. that makes me think, i wonder what other hidden APIs there are.. possible able to just guess a bunch i think
Nice! But unfortunately my car is 2015, so is my HPWC... so I can only assume it's the "older" model with older firmware/hardware that can't run that... and it wouldn't be as precise as the car controlling draw either, because HPWC selector is still in stepped amps, whereas car is single digit amp changes... really wish an API was available!There's a different way to achieve this, by using the load sharing protocol of the Tesla Wall Connector. (This requires wiring something to the wall connector.) There's a thread here:
Nice! But unfortunately my car is 2015, so is my HPWC... so I can only assume it's the "older" model with older firmware/hardware that can't run that... and it wouldn't be as precise as the car controlling draw either, because HPWC selector is still in stepped amps, whereas car is single digit amp changes... really wish an API was available!What about canbus message within the car? anyone?
That's doable, as the car is the one that talks to EVSE and requests the currentNice! But unfortunately my car is 2015, so is my HPWC... so I can only assume it's the "older" model with older firmware/hardware that can't run that... and it wouldn't be as precise as the car controlling draw either, because HPWC selector is still in stepped amps, whereas car is single digit amp changes... really wish an API was available!What about canbus message within the car? anyone?
"response":{
"congestion_sync_time_utc_secs":1545270496,
"destination_charging":[
"location":{
"lat":60.480312,
"long":22.327951
"name":"Unique Home",
"type":"destination",
"distance_miles":1.645089
"location":{
"lat":60.460714,
"long":22.290152
"name":"Holiday Club Caribia",
"distance_miles":2.673828
"location":{
"lat":60.4554,
"long":21.9516
"name":"Kultaranta Resort",
"distance_miles":14.195284
"location":{
"lat":60.163116,
"long":22.732845
"name":"K-Supermarket Kompass",
"distance_miles":24.419037
"superchargers":[
"location":{
"lat":60.442961,
"long":22.605621
"name":"Paimio, Finland - Tammisilta",
"type":"supercharger",
"distance_miles":8.271776,
"available_stalls":8,
"total_stalls":8,
"site_closed":false
"location":{
"lat":61.181106,
"long":23.885075
"name":"Akaa, Finland - Toijala",
"distance_miles":71.047409,
"total_stalls":8,
"site_closed":false
"timestamp":1545271308686
I just came here to ask if anyone found it yet! Hopefully we see the app update soon!And on that note, I'm excited my Model S got the latest software update earlier today so I'm gonna try to guess the new seat heater / steering wheel heater control endpoint seeing as the mobile app update with support for it hasn't been released yet.
